Palm Zire 71 Handheld Logo
Question about Palm Zire 71 Handheld
I have a cnc gcoder application on the palm zire 71 which i cannot open maybe because someone delete from the sd card , how do i recover it
Posted by ronenlou on
5 Related Answers
Anonymous
  • 15 Answers
SOURCE: Zire 72 does not recognize the SD card
Have you used this card long and what size is it?
Posted on Jul 27, 2007
Anonymous
  • 589 Answers
SOURCE: help
All of the instructions (there are a few different ones, getting started, user guide, etc) can be viewed / downloaded here, directly from Palm:
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,CASE=obj(20198),ts=Palm_External2001#zire71
Posted on Apr 09, 2008
ctau
castletech
  • 372 Answers
SOURCE: the information on my Palm Zire 71 all appears to have been lost.
looks like it's completely gone, hope you kept backups.
was the data stored on the SD-Card, if so try putting the sd-card in a computer/card reader.
Posted on Mar 20, 2009
Anonymous
  • 164 Answers
SOURCE: Palm Zire 71 handheld does not come on, did a hard reset, nothing
Confirm that both the cradle and the PDA ports are clean and free of dust or dirty.
Also, check your AC wall adapter to confirm that is working. The output should be +5.0 volts DC. Any repair shop has a multimeter need it to check it in no time.
If everything appears is OK, then confirm the PDA is properly placed in the cradle, and that the PDA is not loose on the cradle, indicating that the port contacts are not touching.
Best regards,
Posted on Jul 25, 2009
Steve Green
  • 87 Answers
SOURCE: forgot password to hot sync palm zire 71
You can create a new profile and set your options again. It's more work but it will solve the problem.
Side note: I use a great program called eWallet from iliumsoft that supports Palm, iPhone, Windows Mobile, and more to store passwords in. Works great.
Posted on Sep 09, 2009
I need to replace my battery in my zire 71 but cant find how to open it up.
Hello there,
If your palm zire 71 is still under warranty, I would suggest to bring it to the authorized service center for assistance as opening your Palm may revoke the warranty. But if it is already out of warranty, below is the link that could guide you and which includes illustration on how to do it correctly.
http://www.pdainternalbattery.com/zire71install.html
Hope this helps. Goodluck!
The information on my Palm Zire 71 all appears to have been lost.
Need Palm Zire 71 Software
Exactly what software are you looking for?
Despite you have no software CD, you can get in PalmOne web site, and in the support and download section, you can download all the basic and need applications and software for it.
Best regards,
Palm Zire 71... mind of its own
first use the digitizer in the prefs program on your palm
if that doesnt work someone or something has damaged your screen by pressing too ******* it and youll need to find a screen replacement Palm offers the safest and best job for 140 or something like that i recommend going somewhere else (to save money), just do some research and know who you're sending your palm to first
No display
Hello LyMaBa
Do you have an SD card inserted in the PDA?
If so remove it and restart your PDA.
Did the problem go away. If so, please, go HERE for the Zire 71 Expansion update or HERE for the SD/SDIO update.
You can find all the manuals for the Palm Zire 71 PDA HERE.
If you don't have a SD card inserted, you might want to try performing a WARM RESET of your PDA. Youtube has a video on this process HERE.
You can find instructions HERE for performing a reset ("warm" or "hard") on your Palm PDA.
You can find other software, info, downloads, etc.
HERE for your Zire 71.
If performing a "warm" reset doesn't work, try performing a "hard" reset.
*** WARNING!!! ***
YOU WILL loose ALL of your data on the PDA by performing a "hard" reset so make sure it's data has been synchronized w/ your computer software (Palm Desktop, Microsoft Outlook, etc).
* If the information I provided you w/
* resolved your problem or lead you
* to a resolution for your problem or
* an answer to your question, then, a
* "FixYa" rating would be most
* appreciated. @:)
* (You can assign the same rating to
* more than one expert who participated
* in solving your problem.)
* It is best to wait until the problem
* has been resolved b4 rating the experts'
* solution(s). Once you enter a rating,
* the problem will be closed and we will
* not be able to continue to assist you.
* Very often it will take more than one
* exchange of information between you
* and an expert in order to resolve your
* problem. If a proposed solution doesn't
* work for you, don't rate it yet. Instead,
* post back here letting us know and we'll
* continue to work w/ you until we find a
* solution that does work for you.
* Thank you
* BJ @:)
My palm zire 71 does not ever synchronise to mi laptop
You can check in PalmOne web site the user manual for such PDA.
There are all the instructions in how a synchorinzation is done, and how to add new applications to it.
Best regards,
Why doen't my Palm Zire 71 have hardset area
Check out the picture at the following link: http://www.palm.com/us/images/support/kb/articles/hs/30113_Zire71.gif
2answers
Zire 71 Power probelems
it is wise to try a to reset ur zire while it is on charge...otherwise I suggest u to send it for repair again. best of luck.
Open Questions:
Top Palm Computers & Internet Experts
Muzahura Frank
Marvin
Marvin
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
