Question about Schlage Camelot Deadbolt Keypad, Satin Nickel #FE595VCAMXACC619
Schlage camelot key pad does not engage exterior locking knob when you press the schlage button. I have tried three different locks.
Posted by hdennison on
Coaltowner
  • 963 Answers
Here is a link to the installation instructions:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
It sounds like you may have the Turn Lock Feature disabled. View and scroll down in the instruction sheet to the Troubleshooting portion, where it says " Pressing (the) Schlage (button) does not rotate deadbolt" The solution is to push the PC button, then the Schlage button, then 7 to enable the turn lock feature.
Here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Posted on May 06, 2011
Schlage deadbolt
I don't have a direct answer, but here is the contact info you need for customer service:
Olathe, KS 66061
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
You also need to check the operation with the door open versus the door closed--to make sure that you haven't developed a mechanical bind between the door and doorjamb. If all else fails, the lock should be under warranty!
Jan 26, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
How do i change the code on this lock
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
Jan 31, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Hi, I have recently moved into a new home with the Schlage BE365VCAM619 Camelot Deadbolt Keypad, Satin Nickel installed in the front door. We weren't left with any manuals or anything and have no idea how...
There is a video on this page, showing how to change codes.
Jan 10, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
I would like to program the schlage deadbolt keypad using my personal code.
There is a video on that page.
Dec 18, 2010 | Schlage Camelot Deadbolt Keypad, Satin...
Instructions needed for changing the keypad combination of a Schlage Camelot Keypad Lock 26D. I lost the instructions. Please advise. Send information to [email protected]
Dec 17, 2010 | Schlage Locks & Locksmithing
Need to chanfe code
Dec 17, 2010 | Schlage BE365-CAM BE365CAM619 Satin...
Change code
There is a video for changing codes on this page!
Nov 29, 2010 | Schlage Camelot Deadbolt Keypad, Satin...
Installation information. Thanks
Nov 28, 2010 | Schlage Camelot Deadbolt Keypad, Satin...
How do i change my code?
Nov 27, 2010 | Schlage BE365-CAM BE365CAM619 Satin...
Manual for changeing code
Nov 12, 2010 | Schlage Camelot Deadbolt Keypad, Satin...
Schlage Camelot Deadbolt Keypad, Satin Nickel #FE595VCAMXACC619 Logo
785 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Mike
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
