Question about Sony XPlod CD Player w/MP3 Playback CDX-GT40W
I have a sony explode cd player. It is an older one and has been sitting in a garage for about 3 years. We hooked it up today and my subs will not play when a cd is playing but the subs will play in tuner mode. Any suggestions.
kenw392
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sony Master
  • 2,226 Answers
It sounds like you are using the blue wire (power antenna remote turn on) instead of the blue/white wire ( amplifier remote turn on) to turn your amp on. The power antenna remote turns off when leaving tuner mode.
Posted on May 02, 2011
  • bzim85 Jun 14, 2011
    Thank you I had the same problem and changed wiring around and that seemed to be the fix appreciate it
2answers
My cd player will read the disc and starts playing but there is no music out of the speakers
I have the same problem, my sony explode i just hooked up will only play the radio not the CD or Aux. Like the CD Plays but no sound out of it at all.
Sub cutting out
Check the 12v wire running from the battery to the amplifier. Also the sony explode is a garbage subwoofer compared to the Alpine.. sony (they say 1200w max but its more like 100w to power the thing) Amp could be going. Is the amplifier hot when running. If there is a burnt smell comming from the amp, its the amplifier
1helpful
Sony xplode cd player sub problems
Switch your blue wires around.
You have put the remote antenna wire to the remote turn on of the amplifier. The radio cuts off the power to the "power antenna" when you switch to a different mode... so your amplifier is now losing the turn on signal it requires to stay on.
Simple 2 minute fix.
Thanks for using FixYa - a FixYa rating is appreciated!!
Help asap
hook blue wire to ur radio to amp remote
I need help with a system that I just bought.
Well it should be like this...Your amp is prologic which means that it has 5+1 outputs (sub out may be for active sub).Connect your speakers on specific output for each one (center,front left,front right,rear left,rear right and sub).Other devices,CD,tuner...connect to the amp with signal RCA-RCA cabels.On the back of the amp you have all marked inputs.You wasn't specific what do you want to hook?!If you want to hook this "new" to kenwood connect rec out of it to aux in on kenwood.If oposite kenwood rec out to "new" aux in.Hope that this is what you need
2answers
No sub when listening to a cd
THE PROBLEM YOU ARE HAVING IS THE REMOTE WIRE ON THE EXPLODE IS BLUE AND WHITE AND THE BLUE WIRE IS FOR THE POWER ANTENNA
Sony XPlod CD Player w/MP3 Playback CDX-GT40W Logo
Top Sony Car Audio & Video Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
