Sony Handycam DCR-TRV330 Digital Camcorder Logo
Posted on May 01, 2011
My camera is not working properly ,the switch to turn on stays in camera option and do not slide to play,please tell me if i can do something about it.
Anonymous
Level 1:
Genius:
  • Contributor 1,812 Answers
  • Posted on May 02, 2011
Anonymous
Contributor
Level 1:
Genius:
Answers
1812
Questions
0
Helped
251663
Points
49
This can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
I have a 07 denalixl my camera just stopped working one day it dont switch to camera at all just stays on radio car was never hit or working on recently can someone tell me if its a relay or something went...
Hi you might want to check if your back up lights and your back up sensors are working, this can be a sign of the transmission control module not working properly. There is a controller that tells the radio to switch to camera view. Let me know what you find out.
My everon digital camera show the lock option during capturing a videos or taking a picture it show that my camera is lock. and the protection options are disabled and can't enable.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Mar 15, 2011 • Cameras
1helpful
When i turn camera on it shows card locked and i go to the menu option and that only gives me a few options to choose from. How can I fix the problem
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 30, 2010 • Cameras
1helpful
My Kodak V803 digital camera tells me memory card is protected. (Restart switch on memory card) i have tried to switch the camera of and on and remove the memory card but, the problem still exist. Please...
Look at the memory card itself. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Its telling me memory card is protected { reset switch on memory card} go to review. I dont know what to do.... Please Help me.
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Camera does not take pictures with a 2 gb card and disd play shows card lock. help please
Nov 04, 2010 • Cameras
1helpful
The camera is locked, But i still can use the play mode to watch old photes, buat cannot turn it on to make new ones
2helpful
It will let me record but no play back,it says set to manual but it dosen't play the video back,and even if it's turned off it still stay's on
Your camera's function switch fails(the slide switch at the top,POWER, REC and PLAY select switch). If you have background in repairing, you can clean that switch from the inside with contact clean. Coz what you see in the outside is just a knob, the switch is far inside. Take a lot of care when opening, avoid stress on flexible wires. Good Luck
D80
Make sure you have set the camera to the appropriate mode under the Set Up Menu -- choose NTSC or PAL (for USA it should be NTSC.)  Ensure the proper connections are made to the TV -- Yellow to Video and White to Audio (the camera plays music to accompany your photos).   Make sure your TV is tuned to the proper video channel, which is usually 3.   Now you can turn the camera on.  Now go under the Playback Menu and choose the folder your photos are located in, usually "Current" Now, since there are quite a few options from here, check on page 75 of your manual under Slide Show, and you will see the various options available, such as choosing the music to play.
Unable to take Pictures
So, you're using Ni-MH batteries already, once you've turned it on and then you have to press on the PLAY button to view pictures, i need you to double check the battery type option of your camera by doing the steps below:
- Press MENU
- Scroll to the right until you are in SETUP 2
- Go down to Battery Type
- Switch it over to Ni-MH (for Rechargeable batteries)
- Select Alkaline (for Non-rechargeable batteries)
- Press MENU/OK for changes to be saved
Turn off camera for a few seconds so settings will be refreshed.
Turn on camera without pressing on the PLAY button to double check if it works.
If it does not work still, try to turn on again camera and immediately press on PLAY button to view pictures. Try to press again on PLAY button so you'll be on the mode to
take a picture.
If it still does not work, can you please try Non-rechargeable batteries (Alkaline) with your camera if it won't work with the Nickel-metal Hydride (Ni-MH) Rechargeable batteries.
Make sure you have set properly the battery type of the camera under SETUP 2 for Alkaline.
take a picture.
If it still won't work, then you have to send the camera for Repair.
Register camera online:
- Go to www.samsungcamerausa.com
- Click on Customer Service
- Register under Option 2 Box
- Fill out the required info
- Read instructions
- If website asked you to upload a receipt, just skip that
step and leave it blank
- Take note of the ASC address and online ticket number
that will be generated at the last step
- Turn-Around-Time will be 7-14 business days
Do the following:
- Include a copy of receipt in the box to avail of the warranty
- If you don't have any receipt, include a copy of credit/debit card statement/cancelled check that was used to purchase the camera
- Exclude all accessories when sending camera for repair
(No batteries, memory card, strap, cables, manual, CD)
- Write the online ticket number on top of the box
- Use another box and sealed it properly to avoid damages during shipment
- Check repair status using Online your zip code and phone number as you proceed on the Repair status of the website
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
