Do these RAM cards work with my Dell Inspiron 510 Mini? http://www.amazon.com/Lenovo-240-pin-PC2-6400-unbuffered-non-ECC/dp/B000JLB2R0/ref=sr_1_1?s=pc&ie=UTF8&qid=1304288782&sr=1-1 http://www.amazon.com/Transcend-JetRAM-240-pin-PC2-6400-unbuffered/dp/B000SLHILU/ref=sr_1_1?s=pc&ie=UTF8&qid=1304288641&sr=1-1 http://www.amazon.com/Lenovo-240-pin-PC2-6400-unbuffered-non-ECC/dp/B000JLB2R0/ref=sr_1_1?s=pc&ie=UTF8&qid=1304288782&sr=1-1
You need a step-down voltage converter to convert 220V to 120V.
Amazon has them. One example - http://www.amazon.com/VCT-VT-300-Voltage-Transformer-Converts/dp/B000J65PJQ/ref=sr_1_13?s=electronics&ie=UTF8&qid=1365005058&sr=1-13&keywords=convert+120V+to+220 or http://www.amazon.com/Voltage-Converter-220-240-110/dp/B001ES8YY6/ref=sr_1_2?s=electronics&ie=UTF8&qid=1365005058&sr=1-2&keywords=convert+120V+to+220.
Look for words like "voltage converter", "voltage transformer" and "travel"
well an easy way to do this would be to buy a cheap usb wifi adaptor such as this: http://www.amazon.com/USB-Wireless-Lan-Adapter-150Mbps/dp/B002XGDU9M/ref=sr_1_10?s=electronics&ie=UTF8&qid=1346834082&sr=1-10&keywords=usb+wifi
or a bit more reliable solution would be a wireless card such as this: http://www.amazon.com/802-11g-Wireless-WIFI-Adapter-Desktop/dp/B003OBHE60/ref=sr_1_4?s=electronics&ie=UTF8&qid=1346834141&sr=1-4&keywords=wireless+card but I do not recommend doing this yourself unless you know what you are doing.
The 300W Power Supply Unit is still somewhat under-powered 550W is required so that the computer is powered by a PSU working under minimum load strain and well within its power output capacity. 300W is the original Specification, See here:
Sometimes, positioning the base unit directly on a carpet with a thick shaggy pile, or enclosing in it, during use in a poorly ventilated under desk cubby hole, next to a radiator, or in place receiving direct sunlight, polarised by glass in the nearby windows or some similar place can have a underestimated impact on the base unit's ability to cool itself when in use. Cooling is essential for the CPU, Motherboard Chipset, Graphics Card or onboard Graphics Chip, Hard Drive and RAM Memory. All need to be as cool as possible to work at optimum efficiency and the performance of each suffers drastically when exposed to over hot conditions, particularly the CPU which, from stone cold, can reach the temperature of boiling water within seconds of the computer being powered up and will underperform, overheat and shut down at the merest incidence of over hot conditions. So review all the salient cooling issues, then consider adding a separate, dedicated, fan cooled graphics card, its GPU Fan adding to the efficient cross circulation of cooling air to more of the interior and, also, its own built-in GRAM freeing up the 16Mb, 32Mb, 128Mb or 256Mb of System RAM that the on-board graphics chip borrowed from the RAM Modules. RAM that has to work less hard, works at a cooler temperature and thus more efficiently. The CPU works more efficiently as it no longer has to compensate as much for the loss of System RAM previously commandeered by the on board graphics, so it also generates less heat in doing so. Consider removing the (usually) green coloured, plastic Heat Conduit over the CPU and changing the CPU Heat Sink for a more effective, higher quality one, the leaving the conduit to one side. Cooling is about the rapid movement of vast volumes of air. The conduit works against itself by unnecessarily confining the hottest component in the case - the CPU. See an example here:
Consider also Inexpensive but beneficial, cooling Motherboard Chip and RAM Heat Sinks for the RAM Modules. Inexpensive, underside fan powered Hard Drive Coolers that screw to the underside of Hard Drives. See examples here:
The 550W PSU is necessitated by the extra cooling devices you contemplate installing
I hope this helps. If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. This helps Answerers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
This happend to my Wife's PC. We had to install a USB Sound card. Amazon - Ebay has them for under $10.00 shipped.
Here are some random examples that I do not recieve anything from.
There are 4 used ones that are 4gb at amazon http://www.amazon.com/gp/offer-listing/B000PF9QD2/ref=dp_olp_used?ie=UTF8&qid=1293688077&sr=8-1&condition=used
As for Gear. It's about 20 dollars.
Black http://www.amazon.com/GeeBee-Ultimo-running-armband-players/dp/B001H33Q9G/ref=sr_1_1?ie=UTF8&s=electronics&qid=1293688126&sr=1-1
You cannot buy a USB card with 2 internals and do away with the 4 port powered USB hub because the card reader does need to be connected to a powered USB port.
