Where can i see the barcord scanner on my laptop? what this freezing on the mouse pad? i can also hear a strange buzz noise on my laptop.SMART event has also occurred what shouid i do i need your help?
sounds like you need to replace battery,,its sounds like the fan is making the noise clean the fan.
did your laptop get wet at anytime?if so that would stop keys working.
check to make sure all drivers are in and turnd on.
and check to make sure all programs are upto date.
the buzzing noise is the pump trying to work, but it cannot due to a blockage. unplug the washer and you can lean the washer backwards and remove the pump to unblock. the fill error is probably unrelated, and is an inlet valve issue.
Try to Upgrade your Mouse Pad driver. Your problem would be solved by doing so. I have faced the same problem. I did upgrade Mouse Pad driver and Yes my mouse pad working fine.
Could be having a problem with memory on your computer if you hear it beeping. If you have had your computer for a while you might need to have it opened and get the dust cleaned out of it. It could be overheating.
have you restarted the laptop since you un installed the smart pad driver
because normally windows will re install it on restarting
do you have an external mouse to use temporaily so that you can try the windows updates
they may offer up a driver for the touch pad
or go to
start
control panel
add new hard ware
find the touchpad and click install
or go to the official website
as you have not stated what operating system you are running i cannot find the exact driver for you
but you can search the operating system and then find the touchpad driver
Toys R Us is currently selling the Barbie B-Smart Laptop with the mouse and mouse pad.
In the description it states "The
interactive mouse and mouse pad feature colorful Barbie graphics for fun
navigation through games that reinforce basic computing skills."
try an external USB or PS2 mouse to check if ur mouse pad is having an issue or Windows is freezing it...
alos.... u can use the ext mouse as an alternative
there is an issue in ur mouse pad/key pad...some keys are short or some keys are locked...
with respect to ur CD drive...it issue happens with the use and life of the laptop...
consult a service engineer....
or use a external USB drive...
