Question about HP Photosmart C7180 All-In-One InkJet Printer
I have a code error Oxc18a0001 Ink System Failure, HP Photosmart C7280 All-in-One
Posted by allen_234 on
  • HP Master
  • 6,349 Answers
There are several issues that can cause an Ink System Failure for an inkjet.
First try to reset the printer. With the printer on, unplug the power cord from the printer. Then unplug the power cord from the wall outlet. (If you are using a USB connection, also unplug the data cable from both the computer and the printer.) Wait at least 15 seconds and then plug the power cord back into the wall outlet and then the printer. Turn on the printer if it doesn't turn on automatically.
If the error persists, then clean the printhead. Have bottled or distilled water and lint-free clothes available (coffee filters will work). Note: you should plan on working quickly; the cartridges should not be out of the printer for more than 30 minutes. With the printer on, open the cartridge access door. Wait until the cartridge carrier comes to a stop. Then remove the ink cartridges, then lift the latch handle on the right of the print head. Lift the printhead straight up. Next dampen a lint free cloth (wring out the excess water). Wipe the electrical contacts from bottom to top (do not touch the nozzles) until the area is clean of dried ink. With another damp cloth, wipe the edge between the nozzles and the electrical contacts. With another cloth, wipe the two ramps on the sides of the print head working away from the nozzles. Dry all of these areas with a clean cloth (undampened). Next dampen another cloth and wipe the contacts inside the printer (work from top to bottom). Again dry the contacts. Then put the printhead back into the printer and lower the latch handle. Replace the ink cartridges and close the access door. Then reset the printer again if the error persists.
If the error continues, either the printhead needs to be replaced or the printer needs service. Unfortunately, a replacement printhead is not returnable if it does not solve the problem.
For pictures and details see the HP support site: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=en&cc=us&product=3204785#N998 .
I hope this helps.
Posted on May 01, 2011
How to override error Oxc18a0001
If you have a C6180, the error code you give here is not in the manual, so you better contact HP service centre like the manual explains.
1helpful
2answers
I have error code Oxc18a0001- ink system failure. Can you help
Psil posted a possible solution 29 days ago; I repeat for your information:
just had this exact issue with my C7280. I called HP Tech support, got a body in Bangalore or someplace, and was pleasantly surprised that they were prompt and knowledgeable, and solved the issue very quickly after transferring my call one time to a hardware support expert.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
What to do hp photosmart c1580 series ink system
hat to do hp photosmart c1580 series ink system failure Oxc18a0001
3helpful
2answers
What causes the error message oxc18a0001 for printer number c7280.
This message appears when there is ink system failure.. either the cartridges that you are using got damaged or are refilled and also happens when the memory of the printer goes bad
Same error code on HP 3210 HELP!
Its an internal error which means that there is some issue with the ink delivery system of the unit. Since the ink delivery system cannot be replaced the whole unit needs to be replaced.
No reset or any other steps will resolve the issue.
Wish
2helpful
2answers
Hp all in one c7280 error code oxc18a0001 nothing seems to work can not find error code in the manual
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=3204785
Try the above hp support center document. I know that not all errors that pop up on the printer display will be in the manual, but usually the first few characters of an error code point towards the failure.
Hp photosmart d7200 erro Oxc18a0001
Filling your cartridge with non-HP ink won't cause an error. There are basically two reasons for ink system failure, The cartridge is no good or the ink system has failed. Some of these machines can be reset. But, try replacing cartridge first.
Error message oxc18a0001 ink system failure
Go to HP website, I recall some info there on this
13helpful
3answers
HP Photosmart C7180 All-In-One InkJet Printer Logo
Vinaya Kumar...
Vinaya Kumar...
Ekse
