Computers & Internet Logo
A
Anonymous Posted on May 01, 2011
I put a harddrive from my dell computer in my gateway dx200s. It booted up but I could not verify profit key. So I replaced the dell harddrive with the original gateway drive but now it wont boot. beeps but wont boot. I don't even hear the drive turn on.
jose de jesus sigala
Level 2:
New Friend:
  • Expert 134 Answers
  • Posted on May 03, 2011
Expert
Level 2:
New Friend:
Answers
134
Questions
Helped
25621
Points
233
All you need to do is put back the hard drive to the gateway, theres like a finger print that block the hard drive to come on but if you put back to its own i will come on...if you want to make it work in the dell you need to install a fress os...period...
I have put new hard drive in - When booted up it says - Reboot and select proper boot device or insert boot media in selected boot device and press a key.
there can be two scenarios
1. the harddrive is not installed properly
2. the harddrive is not selected as the first boot device in the BIOS of the computer.
After you install new harddrive, you will have to reinstall the Operating System in the computer as well.
For further assistance, log on to HNetworking.com and use Online chat option
Admin
HNetworking.com
Win 7 upgrade disc not recognized
alright when your computers Boots up it tells you several options such as F2 or F12 when you press this another menu should come up you need to change the way your computers boots up isntead of the harddrive put the CD/DVD rom FIRsT than the rest save and exit your windows 7 disk should be already IN!!! than it will load the little dot will be loading than it will tell you to boot from the disk press any key! press whatever and it will take you to WINdOWS 7!!! i hope this helps you and please leave positive feedback!!
1helpful
I have a dell optiplex gx 620 i install a new harddrive put the os cd in it said no boot device,i put in the dell boot cd it booted the computer up it got to A> prompt and stop loading what do i type in...
First put your Windows CD in the drive.
While booting, the screen should offer you a couple of choices - Enter "Setup" and tell you which keys to press or "Boot Options" and again which key to select.
Try Boot options first, and choose to boot from CD. It will revert next time you boot.
If you choose or have to enter "Setup" . Usually achieved by pressing the "Delete" or "F2" key look for and change your boot options to select you CD drive first but make sure you put it back later.
You may have to re-boot a couple of times to find the commands I mention, they do flash through fairly quickly.
2answers
Gateway mx6453 wont boot up- oper system not found
Restart the computer while tapping the deleate key this should bring you to bios go to advanced and check if the harddrive is listed with it highlighted press enter to enter the sub menu make shure its not disabled if it is enable it hit escape key to exit sub menu go to Boot on main menu set hard drive as 1st boot device set cd/dvd drive as 2nd boot device press f10 to save changes and exit. Try restarting
if you get msg opperating system not found use the system restore disk
Hope This Helps good luck
Please leave feedback
I closed my business last month and my desk top dell dimension was networked with microsoft xp pro and i want to take the hard drive from that somputer and install it in my home computer which is a stand...
HI,
When you remove the harddrive from a computer and plug it into a different machine though of the same model.It would not boot, because the operating system product key is unique to the machine. If you want to use this particular hdd in your home system, make it a secondary harddrive or reload windows on the harddrive again. But doing so , you would remove everything from the harddrive.
Thanks for using Fixya
Proton
I had new harddrive put in my dell 4600. now it freezes up sometimes it wont boot up. now technician says my motherboard is bad .it sometimes takes up too three tries too boot the computer up.. and now it...
I agree with the technician. Contact Dell, and order a replacement motherboard, and get the technician to remove the old motherboard, and install the new one -- it should *NOT* be necessary to reinstall Windows, if the replacement motherboard is identical to the original motherboard.
2answers
Mbr error
1. You can fix the MBR error by booting the Computer with a Windows Setup disk.
2. Boot from the Windows CD, and press "R" to enter the Recovery Console.
3. In the Recovery Console Enter your Administrator password.
4. Type in the following: bootcfg /rebuild
5. Then: fix mbr
6. Type: Exit
Good Luck!!!!!!!!!!!!!!!!!!
I want to have xp on my vista gateway laptop
Hello, Its really hard to downgrade from vista to XP on dell laptops. vista and XP use completely different drivers and dell has stopped writing drivers for XP. But still you can downgrade. You need to setup external SATA harddrive from where your XP CD should boot as it wont boot from your current harddrive that has vista. Even if you set these up and downgrade, Since dell has stopped writing drivers your new XP will not work with many new softwares and applications as you wont have drivers for them. I would advice you to use Vista. Good luck, Please rate the solution. ~regards, Jegan
No boot sector
If you have the resote disk make sure your cdrom is the first in the boot order, put inthe cd let it start up the op system it will req you to format the partition and so forth.. if you dont got the disk and the image was supposed to be supplied as well the n you need to send it back to dell and tell them to send you nother hard drive with factory image,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
5answers
FATAL ERROR MESSAGE/DELL OPTIPLEX GX150 DESKTOP/WINDOWS XP PRO
I have experienced this problem as well, it is either the CD is scratch or the CD-rom lens needs cleaning, however it can read the content of the CD, I would susgest you try a another CD-rom , borrow it from a friend. It works for me.
Grand Canyon Tech
Grand Canyon Tech
