You also can try to tell here what is wrong and what you want.
I'm not sure the manual you can find online (see one other message from me) can be printed. Most of the time you can print a manual, with adobe acrobat reader (the programm is for free all over the net) you can read it on the computer. You also would need the acrobat reader to print a PDF file. Most manuals are in PDF format.
The only time a Navigation unit will grey out the ability to enter an address is if it thinks the car is moving. Check your connections. If you connected the VSS (vehicle speed sense) wire to a tachometer or generator signal then the unit is getting the same signal as if the car were moving.
Click on the Gray/black box for the printable version. You have to create a login and then enter your camera's serial number to access the printable manual.
Go to managemylife.com and type in the model number you provided under the "Manuals" link. Your owner's manual is available in a .pdf (Adobe) format that you can download or print for FREE. I hope this helps you.
if you are using the av ipod cable that plugs into the usb and the red,white,yellow rcas, you will have change a setting in the audio section for the audio to work, if you go into the AV settings, the first option with say AV1 input, press it until it changes to IPOD. you should then have audio, if that doesn't work, the the rcas are improperly connected to the radio. hope this helps
