Question about Kenmore 98702 Stacked Washer/Dryer
I have a Kenmore stackable washing machine from circa 1987 or so, we need to know how to take it apartment. In other words remove the dryer from the washer. The washing machine has died and we are expecting replacement and cannot get it through our door stacked. We need to take it apart to get it through.
Posted by beccamec1 on
Eric Taylor
    Master:
  • 590 Answers
Go to the manufactures website and get a user manual as the information you want will ben in there( how to install the machine) eric
Posted on Dec 27, 2017
5 Related Answers
Anonymous
  • 105 Answers
SOURCE: Sears Model 417 stackable washer and dryer
The model that you provide is incomplete. However, if the washer loads from the top, they cannot be separated. If it loads from the front, they can.
Posted on Apr 10, 2009
praky16
Prakash Ram
  • 744 Answers
SOURCE: Stackable washer/dryer
hi..
When your dryer drum isn’t turning anymore, it’s usually a broken belt. Tearing the dryer apart is usually straight-forward enough but stringing the new belt on the motor and idler pulley can be tricky. The Complete Encyclopedia of Dryer Belt Configurations shows the belt configurations for almost every dryer brand you can think of.
this will fix ur problem..
thank u rate me
Posted on May 25, 2009
Anonymous
  • 89 Answers
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
Posted on May 28, 2009
Anonymous
  • 317 Answers
SOURCE: Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
Posted on Nov 04, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: I need to know how to take apart a kenmore washer.
wood block and rubber mallet.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
What does the code nd mean on an apartment size front loading stackable kenmore washing machine mean
ND, I would suggest means no drain. If the machine is full of water, it wont let you open the door. Put the drain hose into a bucket to drain the water out and turn off the machine, after a few minutes, the door should unlock. Check the pump or the pump inlet hose for blockages.
Dec 23, 2014 | Kenmore 3.4 cu. ft. Capacity Compact...
Kenmore stackable washer wont work on Cold cycle only hot water
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 07, 2010 | Kenmore 98702 Stacked Washer/Dryer
Dec 23, 2009 | Kenmore 98702 Stacked Washer/Dryer
Nov 04, 2009 | Kenmore 98702 Stacked Washer/Dryer
My kenmore stackable model number has been
there should be a number on the belt take it to the spares place and they should be able to match one up for you
Jul 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
hi..
thank u rate me
May 25, 2009 | Kenmore 93702 Top Load Stacked Washer /...
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Kenmore Model 94812301 Stackable Washer/Dryer
try adjusting the feet on the bottom. apart from that the bearings may need replacing.
Sep 01, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Need to replace the heating element in stackable Kenmore model 417.98702891
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Mar 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Disassembly
what are u trying to repair on it?
Aug 20, 2007 | Whirlpool LTE6234D Top Load Stacked...
Kenmore 98702 Stacked Washer/Dryer Logo
96 people viewed this question
Michael Thomas
Michael Thomas
Paul Carew
Nicola Conroy
