Question about Singer Quantum XL-1000 Computerized Sewing Machine
I keep get a connection error. Ck that USB cable is connected and the power switch is on. Each time it comes up. Help
Posted by dacasalena on
Beth Millar
    Novelist:
  • 233 Answers
Make sure you have the USB plugged into the back USB ports on a desktop computer and try each of the different ports on a laptop computer. What Singer doesn't tell you (and probably isn't aware of) is that the back ports provide more voltage than the front ones (and is also true of certain ports on your laptop). The USB cable and your computerized sewing machine require more voltage than the other ports allowed.
Give this a try-it should do the trick.
Posted on May 01, 2011
Connection error, check usb cable....
This may sound silly and I am not trying to be a smarty but mine does that quit a bit and it always because I don't have the on switch on when I pull up my soft ware and if the cord you bought is to long it will not work I suggest only because i do this frequently go back to the original cord hook it up turn it on then pull it up on your computer
Sep 06, 2015 | Singer Futura Xl-400 All-In-One Sewing And...
Futura software says machine isnt connected
Go to the Singer website and down load the driver for your machine.
Mar 30, 2013 | Singer CE-200 Quantum Futura Computerized...
Connect error. check that usb cable is connected and power switch is turned on
what is it not doing? has the machine been sitting up for a period of time?
Mar 11, 2012 | Singer CE-100 Futura Computerized Sewing...
I still get the connection error, but ck usb cable is connected and the power switch is on. Also error comes up cannot run an x86 build of this utility on 64 platform Initializing driver failed. says I...
This sounds like you have a problem with Windows 7 or Vista with the clem driver part.
First, there's a Windows 7 update available at www.Futura-support.com. Click on the lefthand side, then on CE100/150/250/350, etc, etc. Follow the directions CAREFULLY. First, be sure the uninstall ALL Futura software you've attempted to install and reboot your PC.
If for some reason this doesn't solve you're problem, I've posted a set of instructions at http://www.fixya.com/support/r8955271-use_machine_windows_7_or_vista that will allow you to run the software under XP on your Windows 7 machine. This is a bit more complicated a solution, but if you follow the instructions carefully, you should be fine. Try the Futura update first, though.
I hope this solves that problem.
Next, you say you're "still" having the connection error? Did I answer your problem before? I'm going to give you the answer to the problem I had with this, and if I already gave you this please leave me a comment on this. I check back daily, so I'll see it and we'll try and troubleshoot further from there. First, take care of the software problem. Next, make sure you're plugging the USB cable from the machine into a USB port in the BACK of your computer, not one of the front ports or a port on a USB hub. The cable and machine need more power than most of those ports provide, a technical detail that Singer doesn't realize. Good luck!
May 02, 2011 | Singer Sewing Machines
I keep getting a connection Error Message. Please Check that USB cable is connected and power switch is turnedl. I just upgraded to a new computer from and older model computer
Make sure you're plugging the USB cable from the machine intoa USB port in the BACK of your computer, not one of the front ports or a porton a USB hub. The cable and machine need more power than most of those portsprovide, a technical detail that Singer doesn't realize. If you're using a laptop, keep trying different USB ports until you find one that works. Good luck!
Apr 29, 2011 | Singer CE-200 Quantum Futura Computerized...
My computer will not open up futura. it says connection error. everything is connected?
Make sure you have the USB cable plugged into the BACK of your computer, not the front or a USB hub. If it's a laptop, keep trying different ports. The USB for this machine needs more power than the other ports offer (12 V), something Singer doesn't tell you, and probably doesn't even now.
Best of luck!
Apr 22, 2011 | Singer CE-100 Futura Computerized Sewing...
Singer Futura CE100 Connect Error. Check that USB cable is connected and power switch is turned on.
I received an email back from Singer stating that it is not possible at this time to load the Futura software on a 64-bit system using Vista. I have emailed to ask whether it would load if the OS were XP, but I haven't heard back yet.
They said that they were working on finding a fix for this, but they aren't sure that they will since it's a hardware problem.
Mar 02, 2009 | Singer CE-100 Futura Computerized Sewing...
So here's what I did and it worked for me. Somehow the WinDriver that is on the software is uninstalling itself and needs to be listed with the drivers for Jungo for this software to work. I installed the software when I first got the machine with no problems, then suddenly I couldn't open it and was receiving the same connection error. When you go to http://www.futura-support.com/faq/machine.htm#2 to install the drivers, you'll notice their screen shot shows both the CLEM driver and the WinDriver. Check your machine following their instructions to see if you have both listed under the Jungo driver. If not, go to http://www.jungo.com/st/windriver_usb_pci_driver_development_software.html and select the link under "Available WinDriver Toolkits" for your operating systems (I selected WinDriver USB for Windows). It asks a bunch of questions which I didn't know the answer to so I selected "other" on almost everything then entered "NA"or "?" for the other description. Select Download now and it will need to restart your computer. Once done, I looked at the device manager again and now WinDriver is listed under Jungo and CLEM and the software opens, no problems.
This will at least temporarily solve the issue, however, it's a free trial which means the download will expire at some point. Good news is, the windriver is on the futura disk, I just don't know why it's not installing or staying on the machine. I am sending all of this to Singer to figure out what they're missing in the installation files and hopefully get a fix permanently.
Jan 12, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer Quantum XL-1000 Computerized Sewing Machine Logo
Top Singer Sewing Machines Experts
tsalagi152
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
