SOURCE: Wish to insert sim card in Samsung SCH-U350 smooth
You were saying that the phone does not have a SIM card slot. You need to double-check it. If the phone does not have a SIM card slot, you need to bring it to a repair technician to put a SIM card slot, unlock the factory code so that you could use it in other country.
But doing it would void the warranty cause it's against the contract of Verizon and Samsung company.
Have a great day!
Testimonial: "Got the solution I needed"
SOURCE: trying to unlock samsung sch-u350 that currently
It should be the last 4 digits of the cell number, if it hasn't been changed. To reset that, dial *228 send, option one. The phone will be reprogrammed and the lock code will be the last 4 digits again. Please respond and vote if helpful.
SOURCE: sch-u350 phone unlock code
i lost this phone a month ago just found it cant remember lock code
SOURCE: I have a Samsung Smooth (U350)using Verizon. The
To get the Phone to Ring - open the Phone and on the side there is the Volume Control buttons up and Down - press the Up button and than press the OK button to "set" the Volume to high.
I am not sure what you are trying to you with the alram - follow dirctions above and if it is not sloved let me know
hope this helps
thanks
SOURCE: I want to disconnect by closing flip on samsung u350
yes,simply go to setting and reset the phone setting
