MSI L1350D-1672US Netbook Logo
Anonymous Posted on May 01, 2011
Msi l1350d web cam wont show up its almost as if its not there! looked on msi website they say the driver is not downloadable
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2468
Points
9
Press the F6 Button - this will install the webcam driver. Give it a few seconds untill the "Device Driver Installed Successfully" message comes up, and the camera should work
Anonymous
Level 3:
President:
  • Master 2,340 Answers
  • Posted on May 01, 2011
Anonymous
Master
Level 3:
President:
Answers
2340
Questions
0
Helped
716318
Points
6960
For model MSI Model Netbook "L1350D-1672US" The device 1.3 webcab uses the "native driver" is bundled in Operating System ie for OS Win 7(x86) or Win XP (x86).
You don't have to install the webcam drivers it automatically install itself when the OS is being installed.
You can use the "Device Manager" to check & update the webcam device drivers or use the Microsoft Update to update & install the any hardware drivers available.
Hope it helps.
  • Anonymous May 05, 2011
    Press the F6 Button - this will install the webcam driver. Give it a few seconds untill the "Device Driver Installed Successfully" message comes up, and the camera should work.
How do I activate my webcam camera on MSI L1350D netbook?
no OS told
but at MSI.com
get the drivers
and load them
and if this PC has a cam, (vast do not or is and option then)
it works.
How do i reinstall my microphone on my msi L1350
You can download the device drivers from MSI WEB support site, select your model computer/motherboard to download :- http://www.msi.com/index.php?func=downloadindex
1helpful
2answers
How to turn on wifi on my notebook msi l1350d
You probably have the answer by now but press the Fn and F11 keys at the same time until you see the wireless logo pop up.
How do i get my webcam working for my msi L1350D?
Hi, I'm Naldz . If your web cam is new, there is a small disk that goes along with the package. Use this mini disk to install the driver that your computer needs in order for your web cam to work properly with your netbook computer. I hope this would solve your problem.. Have a good day !
1helpful
My Built-in cam in MSI netbook is not working
Try this first:
Hold Fn on your keyboard and click F6 then your web cam is on.
If still the webcam is not working try this:
Go to device manager and verify that web-cam driver is working properly by doing the following:
1. Go to start > RUN > then type in the following in the RUN...
box devmgmt.msc then press enter.
2. The device manager box will appear then look for web-cam driver ("Imaging Device")
3. If everything is working like it should, there should not be an "exclamation mark" by your web-cam driver
If there is an "exclamation mark" then load the driver cd that came with your laptop and install the necessary driver or go to your laptop manufacture's website and download the driver and reboot for good measure.
4helpful
2answers
There is no webcam driver so the webcam is not working
This netbook comes preloaded with Windows 7. Window 7 contains a preloaded driver that supports this camera. I fthe camera is not working, i would delete it and have Win 7 find it again. To do this, start/control panel/system/device manager, find the imaging / input device where the driver would be installed - should be fairly obvious - "webcam" or "camera" label, right click and choose uninstall. Reboot computer after you do this. On bootup, when you reach the desktop it will search and find the webcam.
1helpful
I have a msi CR630 laptop with bult in web cam. but i can not connect it. and its saying can not find it. please connect. but i dont no how to.
Under Control Panel > Device manager look for your web cam. When you locate it under there uninstall the drivers and download the latest ones from MSI.
http://www.msi.com/product/nb/CR630.html
I cannot find a cd to download the web camera into my computer to use it with skype. can i find some free download program online? i have the msi 370I neagra web cam. thank you
go to the link below and then click on the link to download the driver wait for 1 minute click on download and then it should give you a downlaod prompt :
http://www.nodevice.com/driver/download.html#
else go to the manufacturers website and from there downlaod the driver software
Where to find a software for
Try the MSI support website, should be there.
If that does not work, try using a driver finder program. It will also look for compatible drivers if the exact driver is not available.
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
