Question about Kenwood Food Processors
Re: Kenwood multipro FP730 seies. I cannot get any of the attachments which use the drive shaft to work. (The liquidiser and the mill are working fine). I think the problem might be the detachable drive shaft, as this fits very loosely on the power unit - it does not click fast or anything. Or is it supposed to sit very loose?
Posted by chantal_dejo on
irmtfan
    New Friend:
I have the same problem. i bought a kenwood fp921
im sure about locking bowl and lid.
but the drive shaft is loose
Posted on Aug 06, 2011
Liquidiser base jammed
No...No! Don't try any waters there!! Call Authorized Service Center.
Apr 23, 2014 | Kenwood Multi Pro FP730 Food Processor
Liquidiser base
Contact authorized service center.
How do i use centrifugal juicer?
The Instruction Manual for the Kenwood FP730 Multipro Food Processor can be found online here:
http://www.kenwoodworld.com/Global/Instruction%20books%20(User%20manuals)/Food_Processors/57832%20Iss%203%20B5%20FP730%20English%20only.pdf
On page 7 you will find illustrated instructions for the assembly and operation of the centrifugal juicer.
Dec 03, 2011 | Kenwood Multi Pro FP730 Food Processor
Hi - I have a Kenwood Multipro Excel food processor (FP980) and I cannot get the weighing function to work. I do get an error message but it is not in the manual so don't know what to do. Any...
Same here - brand new
The display initialises and it's possible to calibrate - the scales then display a figure which alters as load is applied
trying to zero just turns off
Mar 17, 2011 | Kenwood Food Processors
Kenwood Compact FP180 instruction
Go to the following link and download
http://www.kenwoodworld.com/uk/Products/Processing-Blending-Mixing/Food-Processors/White-Food-Processor-with-Liquidiser/
Though the instructions are for FP 190 and FP 196 but considering the machine is the same and the fuctins remain the same this will be helpful to you
Oct 17, 2010 | Kenwood Food Processors
I have a kenwood chef mod 703c the motor spins and drives the belt ok butwhen i engage the power switch the mixerhead does nothing, does not turn
The problem is that the clutchdog, which is normally engaged by the peg on the liquidiser cover, is worn. Remove the top casing of the machine by removing the 3 screws and all of the outlet covers. Then unscrew the top of the gear box and prise open carefully with a screwdriver to expose the gears. The clutch dog can be unscrewed. Remove the spring that is on the outside of the gearbox and replace it on the inside of the gearbox so that it pulls the clutch dog down permanently. This then needs to be screwed back once the top of the gearbox has been screwed back together. Sounds complicated but it will be obvious when you try it. The machine will then turn the main attachment hub but will remain engaged as for later model machines. Hope this helps. John UK
Jun 16, 2010 | Kenwood Food Processors
Food Processors Logo
448 people viewed this question
Top Kenwood Food Processors Experts
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
