Hi nalin, sounds like you may have a problem with with your defrost timer. Defrost timers can fail due to wear and tear. If this happens during the cooling mode, it will allow excessive frost to accumulate on the cooling coils causing the refridgeration compartment to over shoot its chilling operation in turn causing everything to freeze. Best bet would be to call up a local Appliance Service Technician while the fridge is still manageable so you save on time and money. Also it wouldnt be a bad idea checking the thermostat rotational knob on the rear inner wall of the fridge (if there is one) just to make sure that the machine isnt fully dialed to max chill, hope this helps.
