First of all, you should stop saving any new files to you canon camera (or SD card) or taking new pictures with you camera.
Then find a professional photo recovery software named asoftech photo recovery, which is of high quality and easy-to-use.
Camera Photo Recovery Download
Here are the steps:
Step 1: Download and install the Asoftech Photo Recovery Software.
Step 2: Connect your camera (or SD card, memory card etc) to you PC. If camera does not shown as a drive letter (e.g. E:), you need to take out the memory card from camera and then connect the memory card to computer with a card reader.
Step 3: Scan the camera memory card drive where your lost pictures located.
Step 4: Press "Recover" to save the recovered photos.
This tutorial also helps
How to recover photos from camera
Here's a video tutorial from youtube
Foolow those steps:
1. Stop using the lumix camera immediately and better take the memory card or stick out if possible.
2. Install a data recovery utility on your PC, Recuva is a freeware which I also recommended. See the tutorial from this article to learn how to perform recovery.
3. Connect the storage media to your PC installed such file recovery app.
4. Start the recovery process.
Remember - Never attempt to save more files to the camera memory before your files are recovered.
Be relaxed! Here are my ways for you:
Step1. Stop using this camera in case that any new file would rewrite
your original files.
Step2. Insert this camera to your computer and prepare to restore your files.
Step3. Download a deleted file
recovery freeware to your computer and start to retrieve all your deleted files
back:
http://blog4mark.blogspot.com/2012/12/deleted-files-recovery.html
In fact, this freeware has ever
successfully saved all the inaccessible data of my friend off from his camera.
So, I believe it can also work successfully on your camera memory card, too.
Simply read more information of this
freeware here:
http://www.freeware-fix.blogspot.com/2013/04/data-recovery.html
Step4. Save and back up all the restored files on a different memory card
or drive in case of data recovery failure.
Try using this free data recovery software (remember that you need to do the recovery as soon as possible): http://www.piriform.com/recuva/download
Hope that helped. good luck.
