Question about Bose Wave Radio
How do I hook my Bose up to my vizio HD tv? - Bose Wave Radio
8293opae819
    New Friend:
I have a Bose headphone and a Vizio HDTV. How do I hookup the headphones to the TV?
Posted on Jul 30, 2011
I have a bose acoustomas system. It does not have HDMI inputs on the bose amp which denies me hooking a blu ray dvd to the system to access sound for the speakers thru the amp. I want to have dvd and hdmi...
Simple.Depending on the number of HD gadgets you have,you need either 2 or 4 channel HDMI converter.Connect the HDMI output to your tv and connect other equipments to the various HDMI,VGA,component and composite inputs,including your Bose System.
Dec 04, 2013 | Bose Audio Players & Recorders
Can I hook up the Bose Companion 2 series speakers to my HDTV and get acceptable sound?
Well if you currently find the sound of the Bose acceptable and your inbuilt HD TV speakers poor, then the answer is yes. Should you not like the sound of the Bose, plugging them into an HD TV won't make them sound any better :-)
Just use the headphone out of your HD TV to connect. You may find you need to enable the headphone socket/volume via the menu settings on your HD TV
Dec 14, 2010 | Bose Companion 2 Series II Multimedia...
I an lg47 240 hz flat screen hooked to a bose 3-2-1. I got the dvd to play through the bose and sound working through both the bose speakers and tv speakers, but when I try to get the tv to play through...
if you are using a hd reciever make sure the audio output goes directly to the bose system... if you do not have an hd reciever make sure its audio out on the television that you are using if you do have it hooked up right make sure the bose 321 is on the right input such as audio in!!!
if it still is not working exchange it.
Nov 18, 2009 | LG 47LG60 LCD TV
I have a Vizio P42HDTV10A with a Bose 321 system and no sound
Check you cables. make sure that the Dish Box is hooked up and if you are run'n your cables from the Dish Box to the DVD player then you will have to keep the player on.
Use to work for DirecTV i got this all the time
Aug 25, 2009 | Vizio GV42L 42 in. LCD Television
TV audio through Bose Lifestyle 38
Did you select TV input on your AV38 Bose system and same thing for VCR. it should work unless from your TV audio if you watching HD signals some of the program had copy protection so it turn off the video and audio out at your TV output monitor that for TV
For VCR it must work make sure you select VCR input on your AV38
I hope that give some ideas
Dec 15, 2008 | Bose Lifestyle 38 System
NO SOUND FOR TV BUT I HAVE SOUND ON DVD
the bose has to be hooked up to the cable box output and video 1 on the bose. This is the only way it will work
Nov 14, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Jan 18, 2008 | Bose Cinemate Digital Home Theater System...
Need Universal Remote Code for Panasonic DVD Home Theater Sound System
Need a remote for a Bose CINEMATE Digital Home Theater Speaker System. Where can I find one?
Dec 26, 2007 | Bose Cinemate Digital Home Theater System...
Home Theater install
yes sounds about right what you are doing as long as you have 2 digital audio 'inputs' on your Bose to get the audio from the dvd player and cable box. Apart from your last part "I will then use Digital Audio from the Bose to the TV." The tv will only downrate the audio to two channel stereo, so its not worth puting audio through the tv as you only get stereo anyway, so might as well let the tvs speakers power it out themselves.
Aug 17, 2007 | Bose Lifestyle 28 System
Bose Wave Radio Logo
412 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
