Hi eherndl,
The failure Oxc05d0082 description is a pump stalled error, it is often caused by the ink system has failed. To correct this error please follow the steps below.
1. Power drain.
Please unplug the power cord at the back of the printer. Press and hold
down the power key for 30 seconds then release the key and plug the
power cord back in.
--> if this doesn't work please proceed to the next step.
2. Partial Reset.
Please unplug the power cord at the back of the printer.Press and hold
the # and 3 keys together and while holding them plug the power cord
back in. Check if the problem is resolved.
If Not
3. Semifull reset:
Unplug the power cord from the back of the printer again. Press and
hold the # and 6 keys together and while holding them plug the power
cord back in.
4. If you're still encountering the same error, please remove all
the print cartridges (with the system powered up). Clean the copper
contacts with the help of a lint free cloth then reinstalled them.
Allow the printer to go through its normal sequence then go to the Setup, select tools, then clean print head.
Hope it helps.
Thank you for using FixYa.
