Question about Briggs & Stratton Briggs and Stratton 30335 4000 Watt Briggs Stratton Pro Generator
I have a Briggs and Stratton Elite series5500 watt portable generator. I cannot get it started. It has gas and oil but will not start. What could be the problem
Posted by flexxnatl on
EugenesDIYDen
    Guru:
  • 479 Answers
Ensure choke is turned on while starting.
Ensure spark lead is fully pushed onto plug.
Remove spark plug and check there is a spark by keeping spark plug against body of engine and cranking engine, if no spark check there are no broken wires in ignition circuit.
Turn off gas tap if present. Remove the float bowl while holding a container under it to collect any gas. Turn on tap and check the fuel flows freely.
Check the air filter is clean. If it has foam elements these can be washed with warm water and detergent, rinsed and then oiled with a teaspoon of oil evenly distributed through the foam.
Posted on May 01, 2011
We have a Briggs & Stratton Elite Series 5500 watt 8200 starting watt generator, it locked up on us last winter & we can't find out why, what can we do
If the engine is locked, it could be any one of several things. Most are rather expensive, like: seized due to no oil; broken rod; bad valve, etc. An engine mechanic is going to have to troubleshoot it for you.
Oct 09, 2016 | Briggs & Stratton Electrical Supplies
Briggs 6200 elite generator. Starts runs good no ac output and display is blank
http://www.ebay.com/itm/BRIGGS-STRATTON-GENERATOR-OPERATORS-MANUAL-ELITE-SERIES-6200-RUNNING-WATTS-/401042177246 $14.95
May 30, 2016 | Briggs Electrical Supplies
Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
May 13, 2014 | Briggs & Stratton Briggs and Stratton...
Briggs & Stratton Briggs Stratton 6200 Watt Portable Generator voltage adjust
Usually the cause of slightly low voltage like this is that the engine is not running at full operating RPM. Find the high speed adjusting screw on the govenor linkage and adjust the engine RPM until the output is 220V - 240V
Dec 09, 2013 | Briggs & Stratton Briggs Stratton 6200...
After starting it it dies seconds later like it's out of gas
Check the oil viscosity and level, and also make sure the low oil pressure switch isn't the culprit
Nov 12, 2013 | Briggs Stratton Portable Generator 305cc...
Honda generator leaking gas from carborator
that is your fuel drain screw so if you get any water in your carb you can drain it and it was loose thats why gas drained out of it
Dec 16, 2012 | Briggs & Stratton Measuring Tools &...
Gas got into the oil through carb. changed oil. rope won't pull. 13hp briggs on a generator.
STOP...The engine crankcase is FULL of gas and oil..NOT A GOOD THING...
remove the spark plug,,,drain the oil.. let the engine "air" out,,, have the carb cleaned and set..
Jan 28, 2010 | Briggs Stratton 020273 Elite Series...
Generator is burning oil and choking out
You have/had too much oil in it. After it is brought down to proper level, it may have to burn the oil that is in areas that it should not be in. Another thing that may cause this, is a dirty air filter, can cause enough suction to pull oil around valves, and other places a clean filter will not. It may have oil in the filter too.
Dec 19, 2008 | Briggs & Stratton Power Products 5,550...
Briggs & Stratton Briggs and Stratton 30335 4000 Watt Briggs  Stratton Pro Generator Logo
667 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
Sheldon Dedek
Mike
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
