Question about Mintek DVD-2580 DVD Player
We need the code to type in to control the power on our dish network remote.
Posted by mommaquag on
Mike.H-DISH_Network
  • 246 Answers
Hi my nameis Mike Houston of DISH Network and I see you need the code for the Mintek DVDplayer. We currently do not have a code that goes to the DISH Network remote, wedo have what we call a Power Scan to program the DISH remote to the DVD player.I will send the link to help with these steps, http://www.dishnetwork.com/SupportSection/power-scan-instructions.
Posted on May 22, 2011
Codes for tv remote for dish
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. Dish TV remote control code list is given.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 16, 2014 | DISH Network Televison & Video
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
I need code to use my dish net, remote 5.4ir for my rca shelf tuner rs2664b.
dinaog,
Our remotes aren't guaranteed to work all types of equipment, but I was able to find some general codes for an RCA sound system.
Codes: 638, 704, 727, 635
If you need assistance with programming or have any other questions let me know!
Tommy Faust
DISH Network
Aug 25, 2011 | DISH Network IR Remote Control
I have dish network setup, and vizio 42" HDTV. The Dish network remote is already able to control the TV power and sound options, however, I want to control the TV Setup options too (specifically the...
Hello, my name is Becki Barned, with Dish Network customer service. To get your tv to work those particular functions, you will need to reprogram the remote to the tv, finding a code that works all functions of the tv. Some codes will work the power and volume, but not the other functions. Try these steps:
1. Hold down the TV mode button until all lights at the top of the remote are lit up
2. Press the 3 digit code in
3. Press the pound button
4. Press the SAT button on the top left of the remote.
Here are the codes to try:
505
671
627
864
006
Hope this helps!
Jan 01, 2011 | DISH Network IR Remote Control
Magnavox blue ray dvd. model nbmgf c need remote code for dish network
Hi there! In order to be able to provide the definite codes that will allow you to program your remote to your Magnavox Blue Ray DVD player, I would need the type of remote that you have- this can be found on the back of your remote, it would be displayed as something along the lines of 3.0, 4.0, 5.0, etc. To obtain a few codes that will likely allow you to successfully program the remote I used 5.0 because it is a common remote that is used with quite a few of our DISH Network receivers. The codes you can try for your DVD player would be, 829 (most successful) if not then please try the following, 685, 533, 554, or 556. After trying those codes if your attempts are still unsuccessful you can also check the manual that came with the DVD player from the manufacturer or just contact us here at DISH Network - although I do know sometimes the remote codes can be located in the manual. Hope the codes help & work for you!
-Kirstie DISH Network
Oct 05, 2010 | DISH Network IR Remote Control
I need the Emprex TV remote control code to program into my Dish Network remote control. Dish Network does not have this code.
We would be happy to help you with that. Currently the onlycode we have that will allow you to control your Emprex TV is 597. If this codedoes not work we would recommend doing a power scan.
Power scan instructions:
Step 1:
Press and hold the TV mode button until all mode button back lights illuminate,then release.
Step 2:
Press and release the Power button.
Step 3:
Press the Up button once a second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4:
Press the pound (#) button. If the code entered is valid for the remote, themode light flashes three times.
After doing the power scan please remember to put the remote back into SATmode. Thanks so much for being a valued DISH Network customer.
Phillip Chang
DISH Network Customer Service Representative
Aug 21, 2010 | Proton SRC-2010 LCD Touchscreen Remote...
Hi how can I turn off my Harman Kardon receiver with the 3.1 Dishnetwork remote?
Guest
I have provided instructions on how to program your DISH remote to a different component. I hope this helps.
Address To Other Equipment Using Code
  • Remotes: Multiple Mode Buttons (TV,VCR, AUX)
    1. Press and hold the desired Mode button until all mode button backlights come on, then release.
    2. Use the number buttons to enter the device code corresponding to the equipment. AUX Mode: Before entering the device code:
      • Press 0 for a TV
      • Press 1 for a VCR/DVD
      • Press 2 for any other device.
    3. Press the pound (#) button Note: The light will blink off after each digit is entered and then return to a steady light.
    4. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Here are the codes to try: 640, 672, 751
Ray Calo
DISH Network
Jun 28, 2010 | DISH Network IR Remote Control
Setting my Dish network remote to new tv
customz28,
Since you have tried several codes for your TV, the next procedure to attempt would be a power scan. I have provided a link with the instructions. The link is:
I hope this helps.
Ray Calo
DISH Network
Feb 19, 2010 | Universal Remote Control DISH Network...
How do i program dish network remote to tv ?
Hello sashamarin66, my name is Michael Hurst with DISH Network. I see that you need some assistance with programming your DISH remote to your TV. There are 2 ways to program your DISH remote to the TV. The 1st way would be to use a remote code for the make of your TV. To use the code would need more information on the Maker and the type of remote that you have. The 2nd way to program your remote is to use a Power Scan. Here are the steps for a Power Scan: With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release. Press and release the Power button. AUX Mode: Before pressing and releasing the Power button. Press 0 for a TV, Press 1 for a VCR/DVD and Press 2 for any other device. Then Press STAR (*). Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Jan 15, 2010 | DISH Network IR Remote Control
Need codes for a phillips magnavox for dish network controller
Follow this link and got to the remote section. Once there shoose the type of remote you have and select remote codes to get the ones for that particular remote that may operate the piece of equipment desired. I hope this is of assistance to yoiu and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Jim
Nov 02, 2008 | DISH Network IR Remote Control
Mintek DVD-2580 DVD Player Logo
238 people viewed this question
Top Mintek Televison & Video Experts
Lee Hodgson
Lee Hodgson
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
