Filter lights on your Air Purifier
http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm
One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
When most people think of Oreck, an air purifier is usually not the first thing
IQAir Dental Series Air Purifier
UV air purifiers are very effective at neutralizing airborne pathogens
HEPA Air Purifiers
REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
Ozone Air Purification
Ionic air purifiers come in three different forms
WHOLE HOUSE HEPA
Dehumidifiers - Ebac Orion
Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
Hi Kevin
Model no as requested. Arazona Janus Phoenix Rango. 105kw ip rating 1px2
Thats all that is on the fan unit
cheers s
does not have a filter monitor button has replace filter light, function, on/off, up,down buttons 4 in total on key pad filter light is not a button.
I have tried all of your solutions even holding all buttons down for 20 seconds SEPRATELY and no go hope i have NOT wasted my money as i am very high up in visa nz and we take a dim view of this type of behavior i look forward to working with you further on this issue to set this light.
regards
Stephen
Hi Kevin I have sorced a fix from the internet. and it works. i will list fix for you.
. Turn off control pad
.Hold down down arrow key
.Adjust bottom parameter to number 10
.Push function key filter light will go out and reset filter capacity to 50 automatically all dun.
Note it does not say on my unit what it is except what i gave you guys but we have deducted it is a Phoenix 9 so thanks for your help. Regards Stephen T.
