ALL ESRI ARC Programs as far as I am aware use the Standard GTCO Tablet Works drivers. All GTCOCalcomp digitizers are or were level 1 supported by ESRI and the standard tabletworks driver will work just fine (This only applies to Windows versions of ARC, not Unix or other OS's)
Drivers can be obtained from GTCOCalcomp or from this link at the Interworld Site:
http://www.interworldna.com/GTCO/gtco-drivers.php
If your digitizer has a serial interface use the SuperSet code 01 or 11. If you digitizer uses USB then no superset is active or needed (This only applies to GTCO or GTCOCalcomp Digitizers)
Calcomp or Summagraphics digitizers will need to be set to 9600,8,N,1 with High Resolution Biinary output to work with Tablet works. Hope this helps you
