Health & Beauty Logo
Posted on Apr 30, 2011
My scooter is too slow,the battery charges,but it only drives at very slow speed,while going backwards it goes fast.Can you tell me what to do?
Anonymous
Level 1:
Scholar:
  • Contributor 50 Answers
  • Posted on May 02, 2011
Anonymous
Contributor
Level 1:
Scholar:
Answers
50
Questions
0
Helped
22101
Points
73
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. In the future give as much info about the scooter as possible.
1. Replace the throttle pot and or the speed pot.
2. Sometimes even batteries that take a charge are not strong enough to run the scooter. Have them load tested at an auto parts store to make sure. If you have bad batteries that will make you scooter do what you say it's doing. Don't forget your reverse speed is only 1/2 as fast as the forward speed on all scooters.
Good Luck
Tim
Testimonial: "Thank you very much,I will test the battery tomorrow "
I lost a indicator light on my mobility scooter and now the battery runs out quickly
Are you losing battery fast with your electric scooter? What a pity! It should have been hard for you to run out of juice in a middle of a commute or lose steam just when you are about to have fun. Such is the downside of electric scooters, electric cars, electric motorcycles, and electric mobility devices that are powered by rechargeable battery. They seem to have the power of a flashlight, but as rechargeable devices, they should have more power than a flashlight. How could you be losing battery fast? You now at least relate to other motorists whose vehicles give away in the middle of the road, and without a refilling station or repair shop in sight.
Why you're losing battery fast
Why is your electric scooter losing battery fast? Something might be wrong with the battery pack or that something in your unit is rapidly depleting your power source. Maybe your charger is defective or not powerful enough to charge your e-scooter. Or the way you operate your unit over certain terrains could be the reason why your unit is losing battery fast. You cannot just say your retailer have sold you an e-scooter with a defective battery.
Done charging but your electric scooter does not start? What if it has no power at all? Think your e-scooter has been properly charged? There might be a broken or loose connection or two in your unit.
Limited power for short distances only? The battery could be faulty or has incomplete charge cycles. Or you either have a defective charger or an old battery. As a battery ages, its capacity decreases, as you should know. If you have the same battery for years, there is no wonder why your e-scooter is losing battery fast.
Charging done for the full required time (usually 6 to 8 hours), yet the electric scooter is still not indicating a full charge? You may have a faulty charger or a bad battery. You should also be wary about a battery that charges faster. If it takes long for an electric car to fully charge, how much more an e-scooter? Anything could be behind your unit losing battery fast.
Battery information
When you buy an electric scooter, be it be a two-wheeler or three-wheeler, always check the specs of the battery pack. Pay attention to the battery voltage and amp hours (AH), not just the chemistry (lithium-ion, sealed lead acid, or lithium-polymer).
Batteries of e-scooters are typically configured in 24V, 36V and 48V. Higher voltages e-scooters are generally faster, but there are factors that could affect performance, notwithstanding battery power, such as rider weight, terrain, and the efficiency of the unit's motor and drive system. One or two of these factors could be behind your e-scooter losing battery fast.
AH is as important as voltage. AH is the measure of battery capacity, an indicator of an electric scooter's range.
One three-wheel electric scooter (on a 300W motor) goes 12 mph and travels a maximum distance of 15 miles per charge of a 36V 7AH battery. Another three-wheeler (on a 250W motor) attains a top speed of 12 mph and a maximum range of 28 miles per charge of a 48V 10AH battery. A two-wheel electric scooter (1000W motor) goes 24 mph and has a maximum range of 10 miles on a single charge of a 36V (three 12 V) 12AH battery. Another two-wheeler (350W motor) has a 36V 10AH battery that ramps up a maximum speed and range of 18mph and 15 miles, respectively, on a single charge. Different electric scooters, different battery specs, different performances. Results may vary.
Knowing your e-scooter's battery (and the other components) is knowing your e-scooter well. That way you will have an idea why your unit is losing battery fast-and how you can troubleshoot it.
How not to lose battery power quickly
As owner, you can do preventive maintenance to avoid losing battery fast and ensure optimal performance of your electric scooter.
  • If your e-scooter has no power after a required full charge, check for any broken or loose connection. Remove the top or deck to reveal the wiring. Inspect the battery pack, switch, brake lever, throttle, and controller. Unsure? Take your unit to the retailer or service shop for check-up.
  • Give your battery a full charge. This will help your electric scooter avoid losing battery fast. Most batteries of e-scooters take up to 8 hours for a full charge. However, do not overcharge for more than 12 hours as this could possibly damage the battery. Charge your unit according to the required duration as specified by the manufacturer.
  • You can prevent losing battery fast by simply replacing it. Replace battery if you begin to notice a gradual decline in charge life. Moreover, replace an old battery with a new one.
  • It is also possible that newly installed batteries could rapidly lose their storage capacity. Have a licensed technician perform a battery test to determine current capacity. Avoid losing battery fast with professional assistance.
  • Don't leave battery uncharged for a long time. Any battery that is left uncharged for over six months becomes defective. You won't be able to successfully recharge a battery that is left uncharged for months. Charge before storage, and when in storage, charge every 30 days.
  • How to know if your battery is getting charged? Check for the indicator light on the charger. If it does not illuminate, battery is not getting charged. Get yourself a new charger.
  • Test your charger's output Voltage with the use of a multimeter. The output voltage should be a few volts above the charger's rated voltage (24V, 36V, 48V). If output voltage is zero or below the rated voltage, charger is defective.
  • Faulty charger port could be another reason why your electric scooter is losing battery fast. Test your e-scooter's charger port by plugging the charger into the port. Look for an illuminated indicator light on the charger. If indicator light illuminates once the charger is plugged into the e-scooter, this means the wires and wiring connectors going to the charger port are in good condition. The charger port is working properly.
  • You can also perform a battery test while operating your e-scooter to see how it is losing battery fast and how long the battery lasts. Give your battery a full charge first, and then drive at full throttle on flat terrain. Most e-scooters will have a range around 30-50 minutes on flat terrain. Battery is already worn-out and in need of replacement if it lasts less than 30 minutes.
  • Another way to check if your e-scooter is losing battery fast is to test the battery voltage, same way you test your charger's voltage with the use of a multimeter. The battery should be above its rated voltage level even if it has been in storage, has been driven or fully discharged and sits for a few minutes. If not, battery may be worn-out or defective. This calls for replacement.
  • Do not attempt extreme stunts with your electric scooter or risk losing battery fast. Though many e-scooters are durable and built to support heavy weight, the metal frames, wheels, and other components are unable to withstand extreme riding activities.
  • Do not drive e-scooter over water or else your unit will start losing battery fast due to battery's contact with water. If you do ride through water, dry unit and battery completely before storage.
  • Do not drive over uneven or rugged terrains. Though some e-scooters are designed for off-road use, uneven or unpaved surfaces can still cause stress on the parts and components. Drive without care over challenging terrains and your electric scooter will start losing battery fast.
Rascal 600t
Yes, sounds like faulty brake.
2answers
Mobility scooter goes slow
driving range of 20 to 38 miles per charge depending on unit. Check out our E Wheels electric power bikes, and mopeds that goes 20 plus mph. Want a fast outdoor mobility scooter, check out the EW - 36 that goes 15 mph. This deluxe outdoor power scooter has a driving range of about 25 miles per charge, depending on the terrain and the weight of the user.
My scooter is too slow,the battery charges,but only drives at a very slow speed.While going backwards drives at a good speed.Can you tell what to do??Many thanks Diana Donald
Hi dianaidonald
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. I know exactly what the problem is. Your problem is the throttle pot or somtime called the engager. or the speed pot.
1.. Replace the throttle pot and or (speed pot most likely the problem).
Good Luck
Tim
Just bought this from an individual who knew nothing about it. Scooter is in excellent condition however it has been sitting for a bit. The problem is the scooter only goes forward when in the High speed...
Jade
This model Drive Phoenix 3 wheel is found for sale at pharmacies and is subject to floor model abuse.
Most common abuse is not recharging batterys and letting them sulfate thus
reducing life of of charge.
I have found that the foward and back-up levers have been bent
by people sitting and squeezing both levers at the same time. the resulting misshaping of the levers results in a very slow speed comand to the controller because of limitted movment of speed control. The result is that main control (turtle/hare) must be advanced to fast (hare) position to get scooter to move.
I have had success straightening levers by carefully bending them in opposite direction on my Phoenix 3W ( which was a clearence item with no warranty.)
The real (legal)solution is ordering a new lever having a technician
replace it so as not to void warranty.
Hope this helps....jth1939
1helpful
Road knight mini, 3 wheel scooter, light flashes o...
Hi. Does the light flash a few times and then pause, and then repeat the flashing ? Count the flashes, it is a fault code. Do you have the fast/slow switch in slow? It might be a speed control fault. How old are the batteries? Might have a faulty motor. Faulty motor or battery leads and connectors. Go for a ride and then check if any of the plugs and sockets feel hot.
4helpful
I have a Pride Legnd..the scooter started loseing speed, I would adj the speed pot and the unit would stop, adjust back down and unit would run, but slow. I left the speed speed controller alone and unit...
hi, first you need to check the connections to the batteries then to the motor controller, and don't dismiss the speed pot, disconnect the speed pot and try a normal 5K pot inplace of it, if the scooters responds you find the problem just a case of getting the right speed pot. Check the freewheel switch, normally it located on the motor side.
Regards
GeWiz.
1helpful
2answers
Have an invacare patriot LX4. Unit takes full
Check to see if the scooter is in freewheel mode. To know if the batteries are bad you need to charge them for 10 - 12 hours and then have them tested with a load tester.
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
