Question about Pioneer VSXD814 Receiver
VSXD814 component problems
Hi my names aaron and i have a VSXD814 and LG dvd/VCR combo i have recently just got a topfield set top box/twin tuner and recorder combo +internal HDD i want to run component from it into the TV/sat pos where i have also run component from my DVD to the back of the amp in DVD/LD and then running component out to my TV when i switch to DVD/LD it works fine but when switch to TV/sat i get no picture ???
I can send pictures if u want
from aaron([email protected]
Posted by aaronmurgia on
2 Related Answers
Anonymous
  • 6 Answers
SOURCE: Digital Audio moved from TV/SAT to DVD/LD
Using the remote control, push the left arrow until display shows Coax1 (or 2, depending on your setup), then push the up arrow to set it to TV/SAT.
Conversely, depending on your setup, you can push the left arrow to display Comp1 (or2) then push the up arrow to set the correct video setting-- DVD/LD I assume.
Posted on Aug 05, 2008
Anonymous
SOURCE: I have a Pioneer VSX-D912.
I have exaclty the same problem. DVD into comp in 1, and my Homecast HT8000 into comp in 2 on my D912.
The dvd gets a picture.
The TV does not.
Looking at the settings I have "Component video Input" set correctly.
I'll add that when I do switch from DVD to TV, I get a scrabled vision of what is on TV for about half a second befoe the TV itself says "No, I can't display that" and gives me the blue screen of 'no signal'
Posted on May 22, 2010
Record tv to dvd on Funai recorder
The Funai ZV427FX4 doesn't have a tuner. You'll need a set-top box (either a digital tuner or a cable box) that has a composite A/V out. Make sure to use a compatible DVD-R or DVD-RW disc (see page 27 of the manual given below). For basic recording, insert a DVD and press DVD to make sure that the recorder is ready to record to disc instead of video tape. (You may need to format the disc for DVD-RW.) Press Rec Mode until the correct mode is chosen. Then press Input to select composite input 1 or 2 (L1/L2). Set this source to the desired channel. Then press Rec. (For scheduled recording, make sure that the unit is set to DVD. Then press Timer. Follow the on-screen cues to set the time to start and end the recording. Otherwise the steps are the same. Then press Timer Set.) See the manual for screen-shots of the procedure.
The manual for this model is available on the product page: http://www.funaiamerica.com/product/product.php?id=877 . Click on the Downloads tab. The direct link is currently http://www.funaiport.com/download/download.php?id=3361&brand=FUNAI . For older Funai units with an NTSC tuner, you will probably still need the set-top box. However, you can either connect the box to the composite video or RF input. (If you want to record a program from a low-power analog station, you would skip the set-top box.)
I hope this helps.
Aug 28, 2016 | Funai ZV427FX4 DVD Recorder/VCR Combo
I have a Magnavox ZV427MG9 DVD Recorder VCR Combo. Do I need a separate tuner? If so what kind? Thanks
Hello
Ofcourse you need an external tuner to receive any RF signals. Your Magnavox is not equipped with internal tuner with it. OK.
Apr 21, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Now that we are on digital will the SD-37VB dvd vcr recorder work or do I have to alter a setting to make this happen
If the unit has a built in analogue tuner, the unit itself will still operate as normal, but without the built in analogue channels - to record a TV show, you would need to connect an external set top box to it (SD or HD - or both).
In other words, apart from a separate set top box, if required, there should be no need to change any of the unit's settings if it works as is. I do not believe this model has a built-in digital (DVB) tuner.
Apr 13, 2011 | Toshiba SD37VB DVD Player / VCR Combo
I have DMEZ 47V DVD recorder/VCR combo and panasonic digital/ HD tv...when I set up to pre record the equipment seems to accept the information ok but when i try to playback all i get is ..."cannot...
The reason for this is simple; the built-in digital tuner does not support HD, only SD. You cannot fix it, at least not economically where the recorder combo is concerned. But you can obtain a separate HD set top box, and connect the outputs of it to the inputs of your combo if you really want to record HD channels. It's crude, but cheaper and easier in the long term, and it doesn't damage your machine.
Feb 17, 2011 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Need to know if I can record from dvd to vcr on a magnavox ZV420MWB vcr/dvd combo
Magnavox ZV420MWB VCR/DVD Combo
The answer is YES YOU CAN! Take advantage of one-touch recording from videotapes to DVD+/-R and RW discs or from DVDs to VHS tapes. A variety of different inputs also let you record from compatible camcorders, external TV tuners or cable boxes.
CONSUMER ALERT: This model does not have a built-in tuner for recording TV programs and will not record copy-protected tapes or discs. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322) or visit the Commission's digital television website at: www.dtv.gov.
Feb 15, 2010 | Philips Magnavox DVD/VCR Dual Player
Connect VCR without tuner to record from television
If it has a scart, you can get a scart lead to connect it to your TV. You would need to set the VCR to the Scart socket, IE: AV1 etc.. to record. You wouldn't be able to change channel on the TV, to watch another channel while recording though. If you had a set-top box, you could connect that up to the scart of the video then record, while you watched another channel on your TV.
Feb 06, 2010 | Televison & Video
Vcr/dvd combo recording problems
You can use a normal set top box, plugged into the AV inputs on the combo, you could even use a seperate VCR for this, as long as it's recieving the signal you want to record.
Apr 21, 2009 | Toshiba SD-V295
Tuner free
Magnavox (philips) is one of the cheapiest dvd/vcr combos that offer excellent quality on the market. If you have a cable box or Directv box, simply use the audio/video connections on the back and connect them in the combo, then you can record from the television programs whenever you want.
Nov 19, 2008 | Philips Magnavox DVD/VCR Dual Player
Can't switch from AV2 to AV1 with Samsung DVD-VR375 DVD Recorder / VCR Combo
To be able to select AV1, you have to first go into the setup menu and set the control set top box setting to OFF. I think you go to the menu >> setup >> features >> set top box control >> select OFF. Note that this has the side effect of erasing any previously stored timer settings.
Sep 05, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
Dvd/vcr combo
I'l make sure, but I beleave L1 and L2 are inputs. You need to select the one where the show comes from, Its it coming from the L1 connector or L2.
Your device doesn't have a tuner input jack. To record TV programs on your DVD/VCR, you need to connect this DVD/VCR to an external tuner device (e.g., set top box, cable box or satellite receiver) that has audio/video output jacks.
Il confirm this and reply to you in a moment.
May 18, 2008 | Televison & Video
Pioneer VSXD814 Receiver Logo
46 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
ThaMp3Doctor
ThaMp3Doctor
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
