Xerox WorkCentre 52255230 Copier Logo
Question about Xerox WorkCentre 52255230 Copier
I have a WC5225. When I switch on the machine the interrupt light keeps on blinking and the machine does not boot.
Posted by austinaranha on
Patrick Carmichael of MRC
    Novelist:
  • Xerox Expert
  • 107 Answers
Try this: 1. Turn machine off 2. After it has completely powered down, unplug the power cord from the wall. 3. Go back to the front of the machine and turn it on and then back off again (remembering to leave it UNPLUGGED from power.) 4. WAIT 60 SECONDS (Very important) 5. AFTER 60 seconds plug it back into the wall and turn it back on.
If problem persists call for service.
Hope it helps!
Posted on May 29, 2011
Why does a Samsung t.v un65ks8000 doesn't power on? Red standbylight keeps blinking on and off and screen lights for about 3 seconds and then out repeatedly
An interruption in the power supply is the main cause of the red light flashing problem. This interruption is often the result of swollen or blown capacitors. Capacitors are a very important part of TVs as they save and release electricity in the TV
My hp cp1025nw printer showing attention and ready light on
If your HP Printer blinking lights that meand printer has some technical or mechanical errors. The HP printer has blinked different lights and that has different meaning and solutions. You can find here why your HP printer blink ready light. Read the causes and solutions to fix the HP printer lights blinking.
2helpful
2answers
My bladeless dyson fan frequently does not work. When you turn the power button on the light blinks blue. I've only had it a month
Hi there, it's Jack at Dyson.
A blinking on/off switch LED light can indicate an interruption to the power supply. However we'd appreciate the chance to check your machine is working correctly - it sounds as if it should be well within our 2-year warranty period.
Please get in touch directly so our experts can help. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Locked light keeps blinking. Is there a reset sequence?
you interrupted the wash cycle. go through a full wash cycle or turn off the circuit breaker that the washer is hooked up to. wait about a minute then turn it back on, that may reset the machine.
Oct 26, 2013 • Dishwashers
The led 27 flashing no stop
Hi
If you are talking about the descale light, you must let the machine quit on its own. The pump has to stop on its own. Any interruption (you stopping the machine) will keep it in the descale mode. Once it stops on its own, the lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle (putting water in the tank and closing and then reopening the steam knob)until all the red lights go away and you only have a green blinking light. Now your finished descaling a compact without a digital display.
How do i reset it after descaling it?
Hi
If you are talking about the descale light, you must let the machine quit on its own. The pump has to stop on its own. Any interruption (you stopping the machine) will keep it in the descale mode. Once it stops on its own, the lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle until all the red lights go away and you only have a green blinking light.
CISCO 2600 Router Troubleshooting
This is the indicator configuration for the 2600, if the lights are yellow there is a problem.
The following indicator LEDs provide power, activity, and status information:
POWER (green)—Lit when power is on
RPS (green)
Off—No redundant power supply (RPS) is present
Blinking—System is booted, RPS is present, RPS failure
Continuous on—System is booted, RPS is present, no RPS failure
ACTIVITY (green)
Slow, steady blinking—System is booting
Blinks during system activity, such as interrupts and packet transfers
I suggest going to Cisco.com for full documentation on this product.
31helpful
Sharp H4 Error message
Hello sir; The code need to reset;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 then press start.
3, if machine work, please don't forget to give me a good rating.
THANK YOU !!!
2answers
Sharp copier sf 2530
Reset the developer by pressing C-CA-0-C - 83-5
Top Xerox Office Equipment & Supplies Experts
Gary
Gary
Clive
Clive
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
