Question about Video Game Consoles & Games
In order to play pirated games on you PS2, you will need a modchip installed, otherwise, the game will not run.
Posted on May 02, 2011
Use mcboot the instructions are in the video link https://www.youtube.com/watch?v=AzLGAqdBHkQ
this works only if you have a original disc after installatio u can use pirated discs
it worked for me just follow the steps carefully
good luck
Posted on Apr 01, 2015
I was experiencing the same problem on my ps2 slim scph-90004. When I put a game in my ps2 it loads but after some time it just freezes at the same spot.I went to many shops but they dont recognize my problem.Then i open my ps2 slim (Warning:Opening of ps2 my void your warranty) and saw the lens which was not adjusted. SO,if you are experiencing the same problem then use the above method(For slim only).Look at the rod near the lens which has two small clips on it. Open the screws on the clips and take out your ps2 lens.Clean it with a cotton.Set the lens in some different position and load your games .
