Sharp 32C-240 32" TV Logo
Posted on Apr 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Morning, i seem to have lost picture on my tv. I just have a blue screen. How can I restore the channels again please
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
114
Points
Hi
we have tv.model no. cs-29400hp that is not able turn on ,when buton on/off pushed for on the tv. only small "tick - tick" sund able to hearing.what is problem?
Chi Chu
Level 3:
  • Sharp Master 8,457 Answers
  • Posted on Apr 30, 2011
Chi Chu
Sharp Master
Level 3:
Answers
8457
Questions
0
Helped
2820362
Points
26282
The tv have a video board problems,that the board,where it is pluging into the CRT-(tv picture tube) that the video board it is dying require trouble shoot and repair by a tv Tech.For now a temp. repair fixed solution.Tries tv turn off and on a few times,the tv video picture should return.
Switching from HDMI2 watching computer back to HDMI1 to TV channels I have no picture coming on the TV. Why ?
Look if there is a FIRMWARE update for your model of TV and the SAORVIEW.
Many a times, the TV lock in with the frequency and will not release until the proper reset command arrives.
Try switching to a different resolution on the computer before you switch HDMI port
Cobra 5550 pro seems to have lost memory
throw it away and learn how to read a road map . plan your destination before hand and you will be fine.
3helpful
Hi we have lost all channels of our hisence tv just blue screen saying no signal please help had channels yesterday
Nothing to worry, You change to AV mode to TV mode and wise verse,
If nothing happen then call the service center, It only two months old.
1helpful
Why does my tv have one blue, one red and one green line at the top of the screen but no picture?
The CRT inside the TV has gone bad. You can either find the make and model of the CRT and replace it, or get rid of the tv and buy another one.
Mitsubishi 50 real projection blue screen
Turners are Bad Signal Board Call Encompass Parts 1-800-638-3328 or your nearest Repair Shop.
3answers
WHEN I TURN ON MY L32 I GET NO PICTURE. I GET BLACK SCREEN THEN LOTS OF COLOR, REDS ,BLUE ,ALL COLORS IN DIFFERENT PATERNS THAT KEEP CHANGING. SOUND IS PERFECT AND I CAN CHANGE CHANNELS AND VOLUMEAND...
It sounds to me like it's stuck in service mode.There is a button combination with the remote to return it to normal. I would call Vizio support and they should be able to help you.
I think it's a combination like [volume -], [channel -] and power but I could be wrong.
2answers
32LG3000 LCD TV shows no picture when resuming from standby
It seems just channel stored data issue.
Please perform Auto Preset / Auto Channel / Auto Tuning (mentioned menu items) and store all channels again.
Hope problem will resolve.
Time TV
By saying that volume and picture controls work, do you mean you can access the TV's onscreen menu? If so, you may need to re-scan for available channels if you are using the TV's internal tuner. If the memory of those channels has been lost, the TV does not know where to "look" for a signal. You may also need to perform a power drain:
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board.
3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on. After this step, try the channel scan again if it didn't resolve the issue the first time.
KP-53s65 multipule problems, hoping for single solution?
sounds like 2 different problems here. first problem sounds tuner related. second sounds convergence related. third issue (cost effective to repair ?) at this point i would replace the set. i hope this helps
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
