Question about Honeywell Heating & Cooling
I am trying to get my air conditioner to go back on. Our Magic Stat(Honeywell) model # CT3300A1009 9224. I had a display on the thermo that said low battery, so I replaced them & now I can't get anything to display on the thermo. The fan works, but the air does not kick on & the face plate says nothing.
Posted by expgirl on
John
    Problem Solver:
  • 7 Answers
No LCD display would suggest bad battery, incorrect battery install, or unit not seated. Fan may not need LCD to display.
Posted on Dec 17, 2017
5 Related Answers
cagreenw1
  • 77 Answers
SOURCE: I have a honeywell thermostat
Remove main stat from subbase. On back of main stat there are some screws used for different settings. Screw "C" if for fahrenheit and celcius. Screw in for fahrenheit and out 1 turn for celcius.
Posted on Jan 17, 2011
Anonymous
  • 432 Answers
SOURCE: Broken air conditioner?
Try another wall outlet. You may need an extenion cord.
Posted on Jun 25, 2007
Anonymous
  • 113 Answers
SOURCE: Air conditioner not getting cold
low on freon by the time u pay someone to repair it u could buy a new one
Posted on Jun 20, 2008
Anonymous
  • 540 Answers
SOURCE: digital thermostat not working
Can you saY, Batteries!
Posted on Sep 15, 2008
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: fan not working on LG air conditioner su/sz/s3 model
Bad fan motor and or start capacitor are reasons that I suspect......Sea Breeze
Posted on Jan 31, 2009
Don't remember security code on thermostat
All Honeywell t-stats have a model # and a 1-800 #. Call them! Have your t-stat apart to see the model#. Or if you don't know how to take it apart call them first. Ask Mr. Google for Honeywell customer service #. Their customer service is usually %100 in helping me when needed.
May 25, 2015 | Honeywell THX9421R5005 Prestige IAQ...
I don't remember the security code to change the settings.
Depends on what t-stat you have. Need a make of tstat and model # or style.
Honeywell VisionPRO IAQ thermostat. No back light. Screen shows characters, but dim. When touched, back light fails to work. All other systems function okay.
this control has an option for back light display in the set up menu. if it has never worked this may be the problem. if it did work then quit you should replace the t-stat. there are many different models as they have advanced over the years. this is a great control. see if you can find the set up manual
Oct 12, 2013 | Honeywell YTH9421C1002 VisionPRO IAQ...
I have a honeywell thermostat magic stat/32 model 3200. It reads celis and not farinheit. Just started doing this.
Jan 17, 2011 | Honeywell Heating & Cooling
Unlock thermastat of honeywell
Do not know what model t-stat you have and they are different depending on what t=stat you have...
Go here and down load the manul for you t-stat which will then tell you how you can unlock it...
Manual Honeywell How to Find Honeywell Manuals
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
heatman101
May 06, 2010 | Heating & Cooling
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Hello,You forgot to wire the O terminal w1 witch is the reversing valve.It is important to check if old stat is using O or B in witch case B terminal=w1 leaving O unused.
Apr 21, 2010 | Honeywell Heating & Cooling
Housesitting. RTH111B model. I cannot keep the
That is a NONprogramable T-stat. There is no program to overide, therefore there is no need for a "hold" option. To set the temp, place the switch on the side marked
COOL
OFF
HEAT
to the desired setting, and push the up down arrows on the front until the display shows 80.
The DISPLAY will revert back to the current room temperature within a few seconds, and will keep the unit on until it reaches the desired temp.
The set temperature remains at 80, it just shows the current room temp.
Aug 31, 2009 | Heating & Cooling
Honeywell digital thermostat stopped working
Sounds to me like you have a low voltage short. If the stat had no display until you installed the battery means there was no voltage for the stat to work. Putting the battery in proves the stat works, no motors turning on probably leads to a blown low voltage fuse generally a blade fuse on circuit board in indoor unit. Good Luck
Jun 11, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
270 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
