Question about Kodak Easyshare M341 12.2MP Digital Camera with 3x Optical Zoom and 2.7-inch LCD
Power goes on, lens extends, lens immediately retracts, power light goes to red, power goes off. elapsed time 2or 3 seconds.
Posted by wrice101 on
Dou dou
    Master:
  • 340 Answers
What type of the battery do you use for you camera? Was your problem as low power warning for full charged new batteries? It maybe helpful, good luck for using Li-ion Kodak EasyShare battery
Posted on Apr 30, 2011
1helpful
I have a 55" LG TV model#55LD520-UA when I turn it on the red stand by light blinks twice and the LG logo and clock flash for maybe 2or, 3 seconds then the screen goes black
Hi there. I would advise you to unplug your tv from the wall. Wait approximately 5 minutes. Hold down the power button on the tv for 15 seconds without the tv plugged in. This is what they call power cycling. If plugging back in the tv does not work; you might have a power board issue. A typical power board/circuit board repair runs from $25 to $125.
Kodak easyshare Z650 lens extends and retracts
I only can think of two reasons. The first, the battery does not have enough power. As a safety precaution it shuts itself down, to avoid damage to the saved pictures. Because if the voltage is to low, it can't write with 100% accuracy.
Second: something is blocking free movement of the lens. This could have a cause inside the lens barrel, and you won't see a thing. It also could be a minute damage on the outside of the lens. Or what sometimes happens while putting the camera on, you touch the lens barrel. I assume you did remove any lens cap attached to the camera.
So if you can't see any damage to the lens barrel, charge the battery and try again.
Lens error restart camera
  • 1. Begin by turning the power on and off 4 times. If this does not work, remove the battery with the power still on, wait about 15 seconds and replace the battery. Once you have installed the battery, turn the power on. You can plug the audio/visual cable into the camera preventing the LCD screen from powering up. This will allow for more power to be directed to extending or retracting the lens.
  • 2. Try using compressed air to clean around the lens barrel area, this may dislodge the debris that is preventing the lens from extending or retracting.
  • 3. Gently tap on the bottom of the camera while holding the camera with the lens facing the ground. Try using the palm of your hand or the rubber pad on the USB compartment. You want to dislodge any dirt or debris that is lodged within the camera.
  • 4. With the power OFF, place the camera flat on the table with the lens facing the ceiling. While holding the shutter button down turn on the power, this will cause the lens to auto focus hopefully seating the lens barrel guide pins.
NOTE: The next step is the most forceful procedure, therefore use extreme caution when performing. Remember, if a click is heard during this step then stop and check to see if the lens error has been resolved. Clicking sounds may indicate that the lens barrel guide pins have reset.
  • 5. While turning the power on GENTLY twist, pull or push the barrel while the lens is extending or retracting. You want the barrel to move in or out evenly. The idea behind this step is to overcome the friction that is caused by misalignments or dirt within the barrel.
1helpful
EasyShare Z885 Digital Camera: unable to power up camera. lens remains fully exte...
If the lens makes a partial movement when you attempt to power up, it is probably dirt/sand that has jammed up your lens in the extended position. First use a vacuum to remove dirt between the lens gap. Next, be very careful, but when you power up, as the lens tries to retract apply a little force to help the lens, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera
21helpful
2answers
My Kodak EasyShare M340 turns on, but then shuts off immediately.
omg! thank you so much Stephan you are th best i just bought the camera for Christmas. Went to the beach yesterday and it sttopped working the method with holding the lens and moving it around i saw some sand come out now it works!!!!!! :-D
Lens comes out, then retracts after charging.
If this camera has a rechargeable battery in it You Will Have to Get a new battery for it(Your Description indicates a Bad Battery Cell). If it uses AA Rechargeable Batteries they will Need to Be Replaced.
Lens will not retract
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
FE-170 - Lens extends & retracts 3 times when powered on.
appears to be power issue in the camera but you can try the lithium AA batteries that are located in the photo section of your stores... they are more powerful than regular AA batteries or else send to repair shop
Shutdown sometimes fails - Lens retracts then immediately extends again
I am having the same problem with my camera. I have to take the batteries out to get it to shut down. I also cannot view my photos on the camera, when I try to turn it to view, it goes to shoot mode.
Lumix lens retracts and extends
Belikes, any external object is trapped in between your Lens Motor and Camera Body. You should consult Authorized Service Personnel to handle this trouble.
Kodak Easyshare M341 12.2MP Digital Camera with 3x Optical Zoom and 2.7-inch LCD  Logo
Top Kodak Cameras Experts
Ekse
Are you a Kodak Camera Expert? Answer questions, earn points and help others
