Bosch offers a kit for installing a wood panel in place of the normal outer door panel. Based on the limited amount of clearance between the bottom of the outer door panel and the toe panel, I would suggest using the kit offered from Bosch. You will also need the last 2 digits of the model # to get the correct kit. After the UC, there is a /, followed by a 2 digit number. This is also needed.
On a further note, you may also need stronger springs as a wood panel is much heavier than the normal outer panel. You do not want the door just falling open, it is a good way to bend the door hinges.
