Question about Fossil Watches
I have a Fossil model JR7855 Big Tic and I just changed the battery and can't get the second hands ( digital ) to work. What do I have to do to get them to wrk?
Posted by gje9898 on
James Herr
Inside the case back on my JR-7855 is a label with the steps to take to change the batteries. The sticker says to short the pad marked "S1" with the pad marked "+". Keep doing it quickly, then check the watch face. You got it right when the seconds start to change on the face.
Here is a view at the inside of the watch. The two points you are looking for are highlighted in red.
Posted on Apr 18, 2012
5 Related Answers
Anonymous
SOURCE: Fossil JR8096 - Display Not Working
hi i have a watch very simalar. They run on two seperate batteries. sounds like one of them is dead. get the digigtal one replaced
Posted on Aug 24, 2007
Anonymous
  • 3 Answers
SOURCE: Fossil Big Tic Watch - setting the correct time on the digital display
The watch is scrolling through the seconds, and is not something that needs to be set. If there is a bottom it is only there to change the way the seconds are scrolling? There are many different types of these, but most are just standard seconds.
Posted on Apr 06, 2008
Anonymous
  • 104 Answers
SOURCE: Fossil Big Tic watch
go to web site they should have directions there
Posted on Dec 31, 2008
Anonymous
SOURCE: I want to change the batteries on afossil big tic
i think it pretty much pulls right out, the kid at walmart did it rather quickly.
Posted on Apr 17, 2010
Anonymous
  • 7 Answers
SOURCE: The hands have stopped on my Fossil Big Tic watch
This watch has 2 batteries so sounds like the main one has gone flat and the display one is still going, you just need to get the battery replaced.
Posted on Nov 23, 2010
Replace fossil big tic battery
Little battery operates the analog. big battery operates the digital second hand on the fossil big tic.
Aug 19, 2013 | Fossil JR8096 Wrist Watch
I have a big tic fossil watch. The flashing second is working properly, but the hand doesnt. It looks like slowing down. How can I fix this problem. Thank you
your watch has two batteries inside, the small battery is the one that had to be replaced. it is under the big battery, the small battery makes the minute and hour hand move while the big battery makes the seconds flashing. i hope that i had been helped you.
Aug 01, 2011 | Fossil Big Tic JR7896 Watch
I have a BIG TIC JR-8529. Is this model obsolete? The watch was not working properly (stopping/slowing down), so I replaced the battery. It seems fine now, but still no digital display in the background...
Since Fossil do not list their instructions under model numbers it is difficult to be sure that you rmodel still exists but if you go to their web site for instructions http://www.fossil.co.uk/webapp/wcs/stores/servlet/ContentView?langId=10&storeId=32553&catalogId=20002&page=instructions
(click on this link to go there) and you will see some instructions for various big tic watches and you can select the one that suits yours.
The only one that I could find that had a single button above the winder used it to cahnge the colour. Pressing this button for 2 seconds will change the colour to "alternating" and the same again will produce a fixed colour. Perhaps this will make the change of display you need.
Often with watches, you need to use a pair of tweezers to short the battery case to the chassis ((often marked "ac"). This seems to be a re-set function, although I have never found an explanation for the need to do this.
If all else fails, look up their contact details and speak to them about your problem.
May 03, 2011 | Fossil Big Tic JR7896 Watch
The hands have stopped on my Fossil Big Tic watch but the digital display still works, like the seconds.
Aug 24, 2010 | Fossil Big Tic JR7896 Watch
I have a big tic watch but after a battery change the digital number display on watch face no longer works,why?
Who changed the battery, you or a watch repair serviceman? Did you replace the battery bar after you replaced battery? Did you check and see if there was a second battery (some watches have two)
You may need to have it serviced. Or try Fossil at :
http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html
Aug 23, 2010 | Watches
Big tic no longer changes color
The big tic has two batteries. The battery for the display may need to be changed and the circuit reset. You can then hold the display button down for 2.5 seconds to cycle through the display function.
Sep 17, 2009 | Fossil JR8096 Wrist Watch
Jul 03, 2009 | Fossil JR8096 Wrist Watch
Oct 25, 2007 | Fossil JR8096 Wrist Watch
Aug 21, 2007 | Fossil JR8096 Wrist Watch
Watches Logo
3,497 people viewed this question
Top Fossil Watches Experts
Janelle Schoonover
Janelle Schoonover
john h
Ngoro
Are you a Fossil Watch Expert? Answer questions, earn points and help others
