If you have made sure it's set to ring and/or vibrate and it's still not working, then turn off your phone and take out the battery. Put the battery back in and turn it on, then see if it works. This will probably fix the issue. If you haven't made sure it's set to ring/vibrate, you can do so by going to "Menu" > "Settings" > "Audio & Ringtones" > "Ringtone" > "Volume" and make sure the volume is up and not on silent. You can also quickly adjust this by the up and down arrow buttons on the side of your phone without having to go to the menu. I hope this helps :)
SOURCE: Setting Vibrate on an AX260 (LG Scoop)
Okay, here's your answer:
1. Open up your menu and go to "Settings"
2. Select "Sound"
3. Select "Alert Type"
4. And finally select ring and vibrate
Cheers!
SOURCE: my lg neon from at&t want play sounds it justs
I dont know my sound is on voume 7 but if someone calls it doesnt ring or make the melody noise whenever i press a button it hasnt been doing that since the past 3 days
