App Crash is a term used to designate application software crashes. If you check the Event Viewer program the error will be reported as APPCRASH.
The following troubleshooting instructions are valid for WIndows 8.1, Windows 8, Windows 7 and Vista. These also apply for Windows XP, but it is recommended you upgrade your OS version because Microsoft is no more providing official support for XP.S
Scan and clean your windows Pc
Reginout Download
Compatible w/ Windows 10/8.1/8/7/Vista/XP By clicking to download,
Exclude the Application Files from DEP
From the Data Execution, the Prevention security feature exclude the app that crashes frequently.
For Windows 8.1/ 8 and Earlier Versions:
- Right click the Computer desktop icon.
- Select Properties from the context menu.
- Click "Advanced system settings" link.
- Click the Advanced tab.
- Click Settings under Performance.
- Click the Data Execution Prevention tab.
- Choose "Turn on DEP for all programs and services except those I select".
- Click the Add button.
- Browse the root folder containing the application that crashes. Add each .EXE file to the DEP Excluded Files list.
- Click OK ' OK.
Turn Off the User Account Control
Disable the User Account Control to prevent conflicts with running application and UAC feature.
For Windows 8.1/ 8:
- Press Windows Key + X simultaneously.
- Select Control Panel.
- Click User Accounts and Family Safety ' User Accounts.
- Click "Change User Account Control settings" link.
- The User Account Control Settings dialog will appear. Move the slidebar to the extreme bottom, i.e. Never Notify.
- Click the OK button.
For Earlier Versions of Windows (7/Vista/XP):
Uninstall Recent Updates
If any new updates are recently installed, do uninstall them. There might be some compatibility issues.
For Windows 8.1/ 8:
- Click System and Security ' Windows Update.
- On the left side panel you will find "Installed Updates" link. Click that link.
- In the new page list of all installed updates will appear. Click the "Installed on" column to sort the list in date-wise manner.
- Right click a recently installed update, select Uninstall. Follow the same procedure for all recently installed updates, if any.
- Click the Start button.
- Type "View installed updates" in the Search Box.
- Press the ENTER key.
- Refer Steps # 5-6 from Windows 8.1/ 8 user's paragraph.
Check Disk for Errors
Start checking for problems pertaining with your hard disk. Bad sectoral issues may cause App Crash.
- Double click the Computer icon.
- Right click your system disk.
- Select Properties.
- Click the Tools tab.
- Click "Check Now" button.
Set the Default Power Plan Settings
One or more installed software may have changed the Power Plan settings. Set the default options that will prevent the reoccurrence of App Crash problem.
For Windows 8.1/ 8:
- Press the Windows Key.
- Type "Power Options" in the Search Box.
- Click the Settings icon.
- Open that from the Search Results.
- Power Options dialog will open. In front of the default power option, click "Change plan settings" link.
- Click the "Restore default settings for this plan" link.
- Click the "Change advanced power settings" link.
- A new dialog will appear. In the Advanced Settings tab click the Restore Plan Defaults tab.
- Click OK ' Close.
For Earlier Versions of Microsoft Windows:
- Press F3 key.
- Open that from the Search Results page.
- Refer Steps # 5-9 from Windows 8.1/ 8 user's paragraph.
Clean Boot the Computer
Use the System Configuration to disable all startups and services to diagnose frequent app crashes and errors.
For Windows 8.1/ 8:
- Press the Windows Key + C.
- The Charms Bar will appear. Click the Search icon at the top of the Charms Bar.
- Type "MSCONFIG" in the Search Box.
- Click the Apps icon, and then open that from the Search Results page.
- Click the General tab in the System Configuration dialog.
- Select "Diagnostic startup" option.
- Click Apply, and then OK.
- Restart the computer for the changes to take effects.
For Earlier Versions of Windows:
- Point to All Programs ' Accessories.
- Select Run.
- Type "MSCONFIG" and then press ENTER.
- Click the Startup tab.
- Uncheck all the checkboxes, click Apply.
- Click the Services tab.
- Check-up the box labelled "Hide all Microsoft services".
- Disable all services as well.
- Click Apply ' OK.
- Reboot the PC.
