Question about Akai PT4298HD Rear Projection Television
We have top of our screen nothing but red linnes with some at the bottom we can the see the whole picture but kind off waves. i have tried the perfect focus button but only goes to 22% thank you and like to hear back from you soon
Posted by garciaimelda on
Edward
  • Akai Master
  • 3,459 Answers
Your TV has whats called a convergence problem. You can get parts, instructions, and installation support from sites such as www.TvRepairKits.com
Posted on May 01, 2011
Canon LCD screen flickering in picture mode
either you have a bad LCD, it is not connected properly, or the image section of the main circuit is bad. Take it back and demand they give you another one
Jul 03, 2013 | Canon EOS 600D Rebel T3i Digital Camera
Red tinted picture
HI,
Try reseting the TV first by unpluging all the cords for 4hrs and then plug it back.
I will be posting more troubleshooting steps..
Apr 03, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
PT-47WX53G green convergence and wave on bottom of screen
Had same problem with Red. Could not adjust. Funny broken lines. Found this link:
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Replaced the ICs. Was disappointed at first 'cause it was still all bowed out, but then realized that the Convergence 2 "target" can be changed with the number keys. Working thru 1-9 and going back to readjust as necessary adjusted each one into perfect alignment.
Problem solved. TV works great.
I should add that while I am reasonable technically adept, I am a software geek and never soldered before... hardest part was getting up the courage to dive in and do it myself. Glad I did.
Sep 24, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Hitachi HD projection TV-red and green wave and alignment problem
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Oct 31, 2007 | Hitachi 43GX01B 43" Rear Projection...
RCA 25GT536 picture has a horisonal wave or wiggle that scrolls from the bottom of the picture up to the top and then repeats. TV worked great before a power surge. Sound is still good.
Any kind of wave form usually is cause by a bad filter, the question is if it's in the powersupply or horizontal section. I would first start with PS. Look for bad capacitors.
Sep 23, 2007 | Televison & Video
Convergence
Loss of power supply voltage to run convergence circuit.verify w/service literature.Hands-on technical help needed.
Aug 24, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green wave-like color distortion over reds
do you happen to have any speakers of any size within about 3 feet in any direction of the tv?? move them if so, I have large speakers about 5 feet from my tv at home and i still get some distortion once in a while with red and dark green streaks.
Aug 15, 2007 | Sony WEGA KD-34XBR970 34" TV
Akai PT4298HD Rear Projection Television Logo
51 people viewed this question
Top Akai Televison & Video Experts
Marvin
Marvin
matt martin
matt martin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
