Question about Foxconn NF4K8MC-RS Motherboard
No Speaker Sound
I just had a 761GXK8MC-RS (with Athlon 64-bit CPU and new power supply) installed into a Dell Dimension chassis. There is no sound coming from my external speakers when plugged into the green jack on the rear panel. Inside Windows XP Home all the sound drivers are enabled and working properly. What could cause this problem?
Posted by jdnimrod on
1 Related Answer
map9966
Mike Peluso
  • 2351 Answers
SOURCE: No External Speaker Sound
Hi jdnimrod,
This is not you're first post about the Foxconn mother board.
You have an issue with the PS2 keyboard as well. This Foxconn model ( 761GXK8 you listed ), is not 100% correct.
Please check this link:
http://www.foxconnchannel.com/EN-US/searcher.aspx?key=761GXK8
Find which is you're board.
Than post back into this answer.
It is important you run the exact CPU that is compatible with the mother board.
Foxconn's Compatibility chart for MB to CPU.
761GXK8MB-ERS/EKRS
http://www.foxconnchannel.com/EN-US/Upload/Compatibility/200606271133082354761GXK8MB.htm
761GXK8MC-RS MB Compatibility chart:
http://www.foxconnchannel.com/EN-US/Upload/Compatibility/200603210922432734761GXK8MC-RS.htm
761GXK8MB-KRS MB Compatibility chart:
http://www.foxconnchannel.com/EN-US/Upload/Compatibility/200606300744394666200606271143263290761GXK8MB[1].htm
I'll help you further once I know the correct mother board.
Mike
Posted on Aug 08, 2008
What is the best upgrade cpu for a compaq presario sr5110nx 32 bit vista O.S... ATHLON 64 (single core) without having to go to 64 bit, and/or new drivers ?
The 400W PSU is going to limit your CPU selection to dual-core at best, although you might be able to get away with a higher-end dual-core CPU if your RAM is not ECC and not dual-channel, and you're not running anything serious in terms of a graphics or sound card or a SCSI array.
Given your current setup I'd really look for a 1.6Ghz dual-core Athlon which has a decent amount of KB in its Level 1 and Level 2 cache, but 3MB for its Level 3 cache.
Anything beyond that ballpark of a CPU upgrade is certainly well within the bounds of diminishing returns, and you should look at getting a new PSU, motherboard, and probably RAM (I'm guessing you're using DDR2 RAM currently).
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/andrew_7b5641a71b84cd85
May 24, 2014 | Compaq Presario SR1050NX (DW257A) PC...
XPS-410 needs to have MCE 2005 Rollup two SP3 replaced by Windows 7 64 bit. Too many problems to list currently but will work limited programs
Not sure what you are trying to do. If you are trying to convert 32 bit to 64 bit Apps, try going to manufacturers website to look for drivers.
Win 7 will actually find the best drivers for your devices.
May 06, 2014 | Dell XPS 410 PC Desktop
Where can i find mixer for dell deminsion dime521
If you mean audio sound Mixer.....go to lower right on screen and click on speaker icon, then on "Mixer".
hope this helps.
May 05, 2014 | Dell Dimension E521 AMD Athlon 64 X2...
I have at current a AMD sempron 3400+1.80GHz processor,socket AM2(940)core VID 1.100V,core speed 1002.2 MHz,bus speed 200.4MHz,HT link 801.7 MHz,stepping 2,L1 data and inst 64 KBytes-2-way,level 2 256...
The main thing is before you go swapping cpu there are some things to consider. 1. the new processor may draw more power than your current power supply can push out. 2. it will probably generate a lot more heat...both are bad..
But if you insist you can get away with an Athlon 64 X2 5600 or 6000+ cpu be careful though because some have different voltages which may not work with your board.
hope that helps.
Feb 03, 2010 | Dell Dimension C521 PC Desktop
For some reason i get no sound or verry little on my dimension
you may need to roll back your sound driver to before you installed the tversity. also try looking in lower left corner to see if you see little speaker. if so double click the little speaker and see if volume is turned up there.
Nov 08, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
I need help upgrading PLZ URGENT dell dimension E521
The most powerful CPU Dell sole in the E521 was the 5600+, 2.8G, Pretty Cheap on EBay
http://shop.ebay.com/i.html?_nkw=Athlon+5600%2B&_sacat=0&_trksid=p3286.m270.l1313&_odkw=Athlon%2C+5600%2B%2C+2.8G%2C+1MX2%2C+Dual+Core%2C&_osacat=0
Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150369
Power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371007
Oct 08, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
Noisy fan
Usually the heat sensor on either the CPU or the mother board through the BIOS software ajusts the sped of the van. Are you talking about the CPU fan , The Main case fan or the power supply one?
Feb 28, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
PS/2 Keyboard not Working
ps/2 means the north bridge chipset is going ( just not totaly dead though ) in time you may notice the usb may not work at 2.0 speeds
Sorry nobody on this planet can repair a ps/2 unless another motherboard is purchased .
Aug 08, 2008 | Foxconn 761GXK8MBRS AMD Athlon 64/Athlon...
Hi jdnimrod,
761GXK8MB-ERS/EKRS
Mike
Foxconn NF4K8MC-RS Motherboard Logo
42 people viewed this question
Top Foxconn Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
