Question about Amana ARB224RCW Bottom Freezer Refrigerator
EVERYTHING FREEZES! My freezer works perfect the only problem I have is that I can't keep a number of things in my top refigerator portion. For example, if I buy lettuce and put it in there it will freeze before the morning comes. Cans bust, water freezes, and everything forms ice crystals. Its like I have one big deep freeze. I have adjusted the temp control and it does nothing.
Posted by nickole_73 on
Chris Huff
    Top Expert:
  • Amana Master
  • 6,289 Answers
Probably need to replace that temperature control. Also check damper. If manual, set to where less air is going to fridge.
Posted on Sep 24, 2017
5 Related Answers
Anonymous
SOURCE: amana side by side ice dispenser leaking water
icemaker wont dump ice
Posted on Jun 19, 2008
Anonymous
  • 19 Answers
SOURCE: Fischer Paykel fridge freezes then stops
sounds more like a defrost problem, check your defrost timer, defrost heaters.
Posted on Feb 21, 2009
Mark Nichols
  • 351 Answers
SOURCE: Ice maker freexes ice together
maybe too much water going in to the ice maker
Posted on Jun 30, 2009
Anonymous
  • 40 Answers
SOURCE: Ice maker freeze ice together
If mechanical or electronic then it has to be replaced with a modified one no way to adjust.
Posted on Jul 01, 2009
shaxaman
  • 13 Answers
SOURCE: upright freezer - bottom freezes, top won't
check the drain system may have got blocked....
Posted on Aug 10, 2009
Refrigerator not working freezer works
What is the model number of the unit?
Nov 09, 2012 | Refrigerators
My freezer is working but not the fridge? is it broken?
There are a number of fridge freezers which use a fan to circulate cold air from the freezer portion to the fridge. After a while the condensation freezes in the ducts and the air can't circulate. If your fridge is this type try defrosting the freezer.
Jun 24, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Admiral SAC224 fridge freezer: fridge intermittently freezes up
To Whiteorchid,
Found a fix for my issue ... hopefully it'll help you.
Up at the topleft rearmost corner of the fridge remove panel to reveal spring attached slots where cold is supplied from freezer. The spring attached had came off one end as there isn't a "slot" for the spring to hold in place (design fault?).Reattached the spring and taped on .... and hey presto fridge now working perfectly again. Hope this helps.
Sep 01, 2008 | Admiral 26 cu. ft. Side-By-Side...
Fan keeps freezing
HI .did you pull the fridge, away from the wall, and clean out the drain tube ,at the back. if not pull fridge away from wall, find the drain tube, and clean. thanks the appliance doc
Aug 04, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Kenmore refrigerator not cooling
Is there frost on the back wall? If so your coil is frozen up and you have a defrost problem. The water coming out of the freezer door could also be caused by the same problem.
May 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Amana ARB224RCW Bottom Freezer Refrigerator Logo
77 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
