Rockford Fosgate Punch P5002 Car Audio Amplifier Logo
Question about Rockford Fosgate Punch P5002 Car Audio Amplifier
My amp keeps cutting out the subwoofer... I checked all the fuses and the wires and everything checks out good do I need a capacitor?
Posted by foxprerunner on
Anonymous
    New Friend:
  • 81 Answers
Your problem is probably that your amp is starving for power. I have a few questions. 1.What size wire are you using for power and ground on the amp? 2.Whats the impedance of your Sub-woofer? 3. How long are the power wire and ground wires.
For starters... I'm going to guess that you usually lose the subwoofer at lower frequencies. The lower the frequency the more power it requires to drive the sub. You also might want to check if you are running the amp bridged but mainly if your amp is trying to push a 50hz tone at high volume, If your alternator cannot provide the required Amperage. The amp will cut out. A capacitor can improve this. Run a power wire from the battery to the positive terminal of the capacitor then from that same terminal run a positive wire to the amp. Connect the ground on the capacitor directly to the body of the car...make sure to scrape off any paint to make a good ground connection.
Posted on May 06, 2011
I have the dual amp xpa 2500 and i ran all the wires and everything but the indicator light wont turn red nor green what can cause that problem?
Check all the wiring again. If you can use a multimeter, make sure your power wire is getting power at the amp. Also, check to make sure your ground is good. Also, check the remote wire for 0.5 amps when the radio is on. This will make sure it sends the signal to turn the amp on. Also, check all your fuses. Make sure to put the fuse in your power wire. Hope this helps.
My subwoofers cut out after 30 seconds of use but work fine during the 30 seconds...my fuses are all fine and i'm running thick wire with an 80 amp fuse connected off battery...I have a lanzar vibe286...
If it's only your subwoofers cutting out and your speakers are still playing and all, try turning gain down on sub amp and see if that fixes it. I know if I crank my amp too high it kicks itself off to try to keep itself from blowing.
I got a ppi d1000/1 amp cant get any sound out of it?
Make sure your remote wire is hooked up in the right spot, also check your rca plugs and consider replacing them, check all fuses to make sure their not blown, a loose or not good ground wire or power supply wire will also cause this problem. If a power wire has a cut in it, that will also cause fuses to blow, as well as with a ground wire cut, ur amp will not be properly grounded.
I got a sony xplod amp 1000 watt everything is connected good the ground wire is on a bare metal surface 12v wire good power fuse ALL wiring is as it should but there is no bass? the green light is on but...
Open your sub-woofer and check the continuity of your bass speaker. Chcek also the fuse of the sub-woofer amp...the fuse might be busted already.
No power in my clarion i check the fuse and the wires is ok
Check your remote wire. (should be a small blue one in between power and ground) You can also take a voltage meter to check that your CD player is sending the remote signal down the wire when it powers on. Make sure your ground wire is securely grounded to a good source. Make sure its not on a painted area, etc. Find a good bolt on the frame or body. If none of this helps, you can open the amp and look for bulged capacitors on the circuit board.
1helpful
I have a fusion 10'' sub with amp built in and i have it all wired and everything. I got power from the battery to the amp my groung is good all my fuses are good and still no subwoofer playing is my amp...
open it up if you can and check internal connections to the sub, if all looks good, open up the amp and check the internal fuse. becareful of voltage hazards
Ive got no power to the amp trough the rem wire unless i connect.
You need a bigger amp and make sure its a two channel. Four and five channel amps are for mids and highs. If you want real bass get a two channel. If you dont want to buy a bigger amp, Go get a capacitor. It acts like a battery charge storage for when your sub needs to hit those real low notes. It takes a lot of power. Also if you get a capacitor your altinater that charges your battery will not have to work so hard keeping your battery charged, Thus not wearing out your altinater and not having to replace it so soon because it will happen.
Another quick fix is turning your gain down. I turn my gain up half way, maybe a little past half way. You might not get the bass hitting as hard but at least it wont shut off on you.
My subwoofer doesnt work
you mean that the SUBWOOFERS connected to the amp cuts off and come back on randomly?? did you bring the SUBS level to a high volume ? i suggest to check first the value of the speaker (ex. 4 , 8 , 16 ohms ) matches the same value with the amp . second , hows the subs connected , in series ? or parallel . you will need a multimeter for this task .
1helpful
6answers
Speakers cut off when bass goes up...
it might be that your wires from your amp to your subs are too thin. since they were relatively new the first three months, they were probably undamaged, but after pushing them too much, they probably have broken wires, and can't get enough power to the subs when turned up, i suggest getting thicker wires before investing in a capacitor, it could save you money.
2answers
Protection Light irritation
If the amplifier goes into protect when there are no speaker wires connected to the amp, the amp is likely defective. The most likely culprit is shorted output transistors. If it's new, return it to the place of purchase for repair/replacement.
Top Rockford Fosgate Car Audio & Video Experts
Marvin
Marvin
Steve Sweetleaf
Steve Sweetleaf
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
