Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Ice maker stopped making
ice. For this problem you have check few things. First thing, is the water
filling in the ice maker chamber and then ice maker not making ice? Or, the
water is not filling in the ice maker chamber so it's not making ice. If the water
is not filling in the ice maker chamber then it's clear that ice is not getting
made due to no water in the chamber. For no water filling, the problem is
either water supply valve turned off so water is not filling. Turn on the water
supply and it will fill. But if the water supply is turned on then the other
possibility is ice blockage in the water fill tube. There is a tube from which
the water runs and enters the ice maker chamber. If this tube is blocked then
water will not enter the chamber. The tube needs to be defrosted, by using hair
dryer. This procedure melts the ice collected in
the tube and water starts running again. But if water fill
tube is completely clear and no ice blockage or any other blockage. Then other
possibility is water valve at the back of ice maker unit. This water valve is
for letting the water in the ice maker. The water valve open only for
7 seconds and in this time the water fills in the ice maker chamber and then
water valve closes and the same procedure runs again in the next
water filling cycle.------- For your information I will mention that there are
two valves. One is the main valve the back of the fridge section. This main
valve lets the water enter the refrigerator and other valve is at the back
of ice-maker section. This other valve lets the water to enter the
ice maker. In most of the cases the fault is water valve at the back of ice
maker section. ------------- The other above possibilities which I gave you is
water not filling in ice-maker chamber so it's not making ice. But
now consider that water is filling in ice maker chamber but it's
still not making ice. Then the problem is ice maker unit itself. This unit is
controlled by main board. But in most cases if water is filling the ice maker
but it's not making ice then its faulty ice maker unit. So see if the problem
is water not entering the ice maker then the water fill tube is frosted by ice
or the water valve at the back of ice maker is faulty. Replace the valve.
------------ You can get required
parts from sears part direct online site or from repairclinic.com site. -------- This will help. Thanks.
Helpmech.
Posted on Apr 29, 2011
SOURCE: Ice maker not filling & making ice cubes
First give me the entire model # on the sticker from the inside of the fridge and I can definitely help you with this. Let's solve it before you rate it.
Posted on Oct 18, 2007
SOURCE: Frigidaire Ice Maker not working
I have a Frigidaire side by side refrigerator freezer MRS20WRGW0. I had the thermostat-defrost replaced yesterday. Now the ice maker isn't working, doesn't have water in the "tray" part that makes ice, but does still dispense water through the door. What could be causing this problem?
Posted on Mar 28, 2011
SOURCE: No ice
see if there is a device the water goes into then another tubes come out and goes to the ice maker, that middle part is bad.
Posted on Feb 06, 2008
SOURCE: Ice Maker does not fill with water
water valve or the ice maker is malfunctioning and not calling for water
Posted on May 07, 2008
SOURCE: The ice maker is not filling with water. The
If you model is the KSCS25INSS it has 2 sides to the water control valve. You can test the coils on each side of the water valve by unplugging each side and testing with an ohm meter. They should measure the same amount of resistance with the meter. If ice maker has no ice you can test it by filling it with tap water and seeing if it will cycle and dump the ice. It is either the thermostat in the ice maker or the dual water control valve on the back. Let me know if you would like my assistance, Thanks, Sea Breeze
Posted on Jul 18, 2009
Feb 16, 2014 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
The ice
maker not filling with water: ---
Its the problem of water inlet valve. It's a
dual valve. This valve has two tubes in it. One for water dispenser and one
for ice maker chamber. The one side of valve is working, but other side of the
valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the
problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 10, 2011 | Refrigerators
Oct 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jun 29, 2011 | Smeg FA561X Side by Side Refrigerator
Apr 27, 2011 | Refrigerators
Oct 07, 2010 | Viking VCSB423 Side by Side Refrigerator
Jul 10, 2010 | Maytag Refrigerators
Apr 30, 2010 | Thermador KBUIT4260A Stainless Steel
Aug 19, 2009 | Freezers
Feb 06, 2008 | Estate TS25AFXK Side by Side Refrigerator
1,597 people viewed this question
