Question about Sony FD Trinitron WEGA KV-27HS420 27" TV
Problem with the Sony FD Trinitron WEGA KV-27HS420 27" TV WHEN TV IS TURNED ON IT SHUTS itself off in a second or two and a light on front blinks 6 times.
Rusty Larmann
    Novelist:
    Champion:
  • 203 Answers
Most of the time this is caused by two ic chips on the circuit board, ic8001 and ic8002. These are components that can be replaced fairly reasonably. If you call a repairman it should cost 95-165 us dollars. However, this is just an educated guess. Good luck, Russmann.
Posted on Apr 29, 2011
Sony FD Trinitron WEGA KV-34HS420 34" TV Stand by
I have the indentical tv and problem. Cost to repair was about 250.
Aug 19, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I have " Sony FD Trinitron WEGA KV-36HS420 36" TV
U have a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders?Can u do basic soldering and uderstand basic electronic?FBT- the flyback transformer,the big black block of a plastic with a red wire with a cap hook to a CRT-tv picture tube.Near the big block of a plastic with a red wire with a cap hook to a CRT picture tube.Inside to the right of the FBT,there are 2 power supply ICS,those 2 ICS are dead.Replaced these 2 power supply ICS near the FBT,will solved this tv LED power light indication blinking and will have stable tv power again,and tv will work.
Nov 29, 2010 | Sony FD Trinitron WEGA KV-36HS420 36" TV
WHEN TV IS TURNED ON IT IMMEDIATELY SHUTS ITSELF OFF. THERE IS A RED LIGHT FLASHING IN THE FRONT RIGHT CORNER BOTTON
The light is hte standby light and it should be blinking a repeating count. That count will indicate the defective circuit. Please post the count and confirm your model to be KV-27HS420 and we can look up the code and provide the probable repair solution.
Thanks,
Dan
Mar 02, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
My (Sony FD Trinitron WEGA KV-32FQ) is not switching itself on?
I think your control board might be your problem can you get a signal out of the normal composite or coaxial outputs?
Suggest download this service manual first
http://depositfiles.com/files/l51shqooy
Aug 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV shuts off
needs an IC in the power supply, very common sony problem, expect to pay $150 - 200 Julio [email protected]
Jul 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv shuts itself off randomly
hi
you have defective power oscillation in power section
this needs to diagnose for a qualified technician
Thanks!
Feb 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony tv
the trouble of your tv is memory
Oct 15, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony FD Trinitron WEGA KV-27HS420 27" TV Logo
270 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
