No audio no video replaced convergence and resistor kit for tv and it flashed a few times and returned to original problem
Posted by Jon Colasono on
francoise cleofas
    Genius:
  • Televison & ... Master
  • 2,432 Answers
Make sure your power supply is normal, check the low and high voltage.and then check bad relay.check if their is a missing + 3.3v voltage regulator for HDMI controller. check shorted part at Y and Z sustain, check for IC fail.
Posted on Apr 29, 2011
Anonymous
    Master:
  • 691 Answers
Check what was done, make sure no bridge in solder, make sure correct amps were replaced, also there maybe fuses blown and need replacing,
Hear chirping sound from power switch, keeps tying to turn on, but no picture.
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio/Video - TV Makes Chirping Sound
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 24, 2010 | Philips Magnavox 51MP392H Rear Projection...
The red and green is separated and there is a double image.
Projection TV sets have two very common problems oulined below.
  • Screen looks 3D
Dec 24, 2010 | Hitachi 57F500 57" Rear Projection...
COLOR IS OFF---LOOKS RED
  • Screen looks 3D
Dec 23, 2010 | Philips Televison & Video
I can barely see the picture
  • Screen looks 3D
Dec 23, 2010 | Philips Magnavox 51MP392H Rear Projection...
The screen is showing a red outline around objects and in double vision.
  • Screen looks 3D
Dec 23, 2010 | Philips 60PP9202 60" Rear Projection...
Double image orange and green
  • Screen looks 3D
Dec 20, 2010 | Philips Magnavox 9P6034C 60" Rear...
46" projection tv ..colours were
  • Screen looks 3D
Dec 16, 2010 | Philips 46PP9302 46" Rear Projection...
I have a Panasonic Projection HDTV that i recently adopted. When i took it home I found a blue "bowing" at the bottom of the video. The experts i spoke to said i need to replace the convergence chips and...
The 2 STK convergence ICS are dead,all the resistors too,if it is smoking and glowing.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it again.Find the correct tv make and model.The convergence kit buy from one of these website's will have all the parts to repair it right this time.
Jul 16, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Picture looked 3d now tv wont come on. red lite flashes 6 times.
Your TV most likely a convergence failure. ( common problem )
  • Screen looks 3D
  • TV shuts down
  • TV Chirps
Here are some photos of convergence problems.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 03, 2009 | Sony KP-51WS510 51" Rear Projection...
My JVC model number AV-56WP30 has a flashing convergence screen
Your TV most likely has a Convergence Chip Failure but I have not seen that symptom before.
  • Screen looks 3D
Feb 28, 2009 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
