Question about Garden
Replaced pull cord on craftsman push mower but wont retract back like its's been pulled all the way out it's all slack. What do i need to do to get it to spring back? It's 5.5hp self propelled mower about 7yrs old.briggs and stratton
Posted by mclaerhout on
kelleyjusa
    New Friend:
  • 10 Answers
If you get this the first time get a lottery ticket fast.
take the recoil off and apart, check to see if the spring end is broken off. (sometimes you can bend a new hook into it but it will usually break because its hardened).
buy the way, Usually you can wind a rope around what the recoil connects to, to start the engine at this point.
take the handle off the end of the rope and wind it around the drum/spool leaving a few inches hanging out.
hook both ends of the spring to their stops and wind the spring tighter about four turns, then thread the end of the rope through the hole and pull on the rope and test the recoil. Don't lt it go.
pull the rope out and put a "marline hitch" in it or use a visegrip pliers to hold the rope out and tie the handle back on.
replace recoil.
if the rope looks fuzzy most all hardware stores have it.
good luck
Posted on Apr 29, 2011
How do i rewind the recoil spring on my craftsman lawn mower?
Normally these small engines use a clock spring to retract the rope.
Remove the cover on the top and you should find the spring either broken or the tab where the spring end has broken off or jumped out of the mount.
You will need to pre-load the spring with enough tension to retract the rope.
Remove the pull handle from the rope, load the spring and then wrap the rope around the pully holding the pully and spring in the loaded position. place the end of the rope through the hole and tie up the handle. The rope should pull and retract without being installed on the engine.
Best explained here...
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jun 27, 2014 | Mtd 22" Yard Machine Push Mower
How do i fix a cord not going back in on a craftsman weed eater/blower combo 32cc
The one way clutch could be broken or jammed. Take off the starter for a closer look.
May 10, 2014 | Craftsman Garden
My Craftsman lawn mower starter cord doesn't retract after mower starts.
I have had this situation before on a lawnmower. I didn't have a craftsman, but is probably the same issue. Basically, the spring that recoils the cord back in either broke or came unwound. When the mower is not running, the cogs on the pull chord keeps the cord from coming out. When the mower is running, the spring is not wound enough to hold the chord in and thus releases or doesn't hold it in.
Try pulling the pull chord assembly off and rewind the spring.
May 05, 2011 | Craftsman Garden
Problems with pull cord ,pull cord not engageing,pull cord is slipping freely.it acts like a bad spring on a briggs,but iam not familiar with this make.
Pull cords are all pretty similar so if you've seen one then etc.....
Does the cord retract?
If it's a broken spring then the pull cord would not retract.
If it is retracting then it's probably dirt, grass clipping interfering with the spring loaded locking lever.
Either way the only way to be sure is to remove the top cover and inspect it visually and clean it out and spray some lubrication on it.
You should be able to do this without taking apart the actual cord and retracting coil spring. It should come off as a unit.
Once you have inspected it if you you have any other questions please let me know.
Hope this helps.
Jun 16, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Replacing a pull cord on a Craftsman mower
u helped tremondous. thank you, being laid-off i need my mower
Mar 29, 2010 | Craftsman Garden
Trying to replace pull cord for kee tm22 push mower. new cord will not retract. replaced with new cord and now cord will not retract when pulled. spring came out while removing old cord but replaced in...
Take off the whole assembly, find and replace the spring, manuually wind up the reel until it is loaded with tension in the direction that will retract the cord. THEN put new cord in through the feedhole then the assembly, then tie a small figure eight knot at the very end of the pull cord, pull it tight so it stays in its recess and then let the cord retract by releasing the tension. - you now have a fully charged retractor assembly. put it on tightly with the three 10mm bolts, reattach the plastic cover and git mowin.
Mar 27, 2010 | Garden
Craftsman Walk behind lawnmower how to replace the starter pull string
Remove cowling to acces pull start assembly. Have new cord on hand. Remove old cord fragments. Wind rotor 4-5 revolutions to tension spring and hold while threading new cord into slot. Knot new cord and slowly let it wind back into assembly.
Jul 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
193 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
