Onkyo HT S3300 center, left front and rear speaker not working.
Posted by phxpkgent on
Anonymous
    New Friend:
    Problem Solver:
  • 11 Answers
Check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Posted on Apr 29, 2011
ONKYO AV Receiver - model is HT-S3910 (B)
Hi,the letters after NG refer to the affected channels - left center, right surround, etc. Do you have speakers plugged into these channels? If yes try to unplage all speakers then plage one speaker at a time,check your speakers if that dosent work for you try to factory rest your unit .
1helpful
Product= Onkyo HT s3300. My 2 front speakers won't produce any sound when I hook it to the Speaker A rear section.I hooked both speakers to Speaker B ports and both produced sound. Thanks. Godale.
Hello Hasnul, for what you comment, it is very possible that the integrated circuit has been burned, that works with the Front System A output and you have to replace it, the Front System B output, works with another integrated amplifier circuit, which is working well
If you have technical knowledge, I send you the link to download the Service Manual of your Onkio and know which integrated circuit to replace
But, I suggest you look for a specialized technical service
I hope you can solve the problem, comment the results
Greetings Franco Dosil
Hola Hasnul, por lo que comentas, es muy posible que se haya quemado el circuito integrado, que trabaja con la salida Front Sistema A y tengas que reemplazarlo, la salida Front Sistema B, trabaja con otro Circuito integrado amplificador, que esta trabajando bien
Si tienes conocimientos tecnicos, te envio el link para que descargues el Manual de Servicio de tu Onkio y sepas que circuito integrado reemplazar
Sino, te sugiero busques un servicio tecnico especializado
Espero que puedas resolver el problema, comenta los resultados
Saludos Franco Dosil
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Onkyo-HTR-380-Service-Manual.pdf
https://www.intl.onkyo.com/downloads/manuals/pdf/ht-s3300_manual_e.pdf
Onkyo HT-R510
have you tried to reset it to factory defaults yet? If it has a vcr button on the front, then hold the vcr button and press power...it should say reset on the front. Might not help, but worth a try.
Onkyo HT-R510 left side speaker garbled
Out put transister could be fried ,Or the speaker is blowin,
No Audio in HDMI THRU Onkyo HT-R380 Receiver
Hello, I am sorry about your issue. I suggest that you contact us at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
I have purchase onkyo 5.1 channel home theater but i am not able to hear sound from rear speaker when a and b speaker setting toggled and subwoofer effect also not getting
The 2 front speakers need to be connected to 2 big banana plug/screw connection marked Speakers A and not the last 2 color coded Push in style connectors,I had the same issue and this was the fix.Look at the quick setup guide closely,I did not look at it close enuff also.
Hi, I am trying to set up my Onkyo ht-s3300 but I am getting no sound from the surround speakers. The Center/Left/Right are working perfectly. All of the cords are installed properly. I am checking the...
did you press surround button on home thearter to turn it on also check speaker wire at connection sometimes if you push wire in to far it will push the plastis part of the cord into to far and stop the metal connectors from touching each other it happen to me being over anxious so just make sure you got a good connection and all speaker wire are good
I have an Onkyo Hts - 580 Theater in a box sytem. Lately I noticed no output from the front left speaker, alos no output when test tone is used. Pkease help.
you might want to switch the speakers that youre using. e.g front left put it to front right and vice versa to isolate if the speaker has the issue or the amplifier terminal.
if the left speaker works on the other terminal then its a terminal issue.
3 speakers dont work
Check to make sure that Speaker B is not pushed. It's on the front panel on the bottom left.
Marvin
Marvin
