screen display on my Dell Inspiron 1545 with MS XP OS- Then I ran diagnostics and got this result- "DST short Test-Failed-Error code-2000-0151 Error message: Hard Drive 1-incorrect staus 3E. Please help fix this problem. Thanks
Thanks for using FixYa. Error E007 means there is a jam in the Fixing/Fuser Assy.
Error E007 is related to a non-detection of the Fixing Film/Upper Roller, the
fixing film sensor didn’t detected the rotation of the film for 6 sec or more
while the fixing motor is driven. Please check the condition of your Film also
check the green handle in this area for paper jam removal if it is broken or
removed, may also cause this error. If everything is fine then try clearing the
error by entering the service mode, you can do it by pressing *(star), then
press 2 and 8 keys at the same time & then press *(star) again.
Now press COPIER>FUNCTION>CLEAR>ERR, to clear the
error code.
Please do rate the solution and revert for further assistance.
The SMPS Fan Error is caused by slow or no rotation of the SMPS Fan.
The firmware solution from Samsung disables monitoring so if the fan
stops the printer will keep working. Thankfully, it's not physically
hard to fix this issue though and can be done by removing 9 screws and
using a little oil.
When i started rebooting centos and i saw the error logged vamw.zend failed. How can i fix it? thanks <--- ask www.zend.com and most probably you're not asking the proper question. garbage in, garbage out.
