Question about Refrigerators
Sir i have haier refrigerator hrf 368u its freezer is working making ice but lower portion is not working properly. it is a direct cooling system without frost free
Posted by tabi304alpha on
D. Floyd Kolb
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on May 01, 2011
Freezer works, but the fridge side doesn't cool all the time.
The mechanism that directs freezer air into the refrigerator portion is not working properly and needs to be addressed.
Oct 17, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jcb 2059 Jen air fridge not cooling freezer o.k.
Its a defrost issue.The freezer works,then cooling starts and then its time to defrost.But in defrost the unit is not working.It can be faulty defrost assembly parts.Or the problem is with defrost timer at the lower back side of refrigerator.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
The freezer door is not sealing properly and seems to be off the track.
the spare seals are available,if the seals are not sealing,then may be its got worn out/ over stretched so it has to be replaced.
These will help.
Thanks,.
Dec 22, 2012 | LG LFX25971ST Bottom Freezer French Door...
I have HRF 340h, and i m facing cooling problem in one portion,
may be evaporator fan is not working or the air flow from the freezer to the fridge is blocked.
May 14, 2012 | Refrigerators
Upper portion (frig not cooling properly) Lower portion (freezer) forming ice on #3 setting.
Is it forming ice or frost? It sounds like an automatic defrost problem. If the freezer frosts up it won't circulate enough air up to the fresh food compartment. Try defrosting it manually for 24 hours by shutting it down and leaving the freezer door open. Afterwards, if it resumes normal operation I would bet that there is something faulty in the defrost circuit, i.e., defrost heater not working or defrost control.
Feb 23, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hello Sir, I am using a double door Haier refrigerator from last five years. It has two containers. The upper container is freezer and the lower container is refrigerator. Since yesterday, the lower...
Please check inside your freezer for the working of the fan and then check inside the lower area for the air flow from the freezer. If you notice that the flow is less it is possible that the air duct is clogged due to build up of the frost.If so then you must shut off the fridge for about 8-10 hours. Once you find that the frost has cleared up then put the fridge on after the cleaning was done. Now check if the air flow is good, if not check the duct and the fan assembly for poor speed. However if the fault is clear now then you must check if the fridge is shutting off after 8-10 hours for auto defrost. If this is not happening then the fault can recur. Hence check you timer unit the heater unit and the thermostat for fault. Also any wire break on the cooling coils side of the electrical wires to thermostat./timer or fan or heater can be a cause. Try this out and check . Good day
Jul 30, 2010 | Haier Refrigerators
How Do i have a Haier HRF-388AE, Do you know how to defrost the Freezer while leaving fridge on?
CAN'T BE DONE AS THE FRIG WORKS OFF THE FREEZER,THE FREEZER MAKES ALL THE COLD AIR FOR FOR FRIG.IF IT'S NOT FROST FREE JUST TURN THE THERMOSTAT OFF TILL FREEZER IS DEFROSTED,IF FROST FREE YOU SHOULD'NT HAVE TO DO ANYTHING,HOPE THIS HELPS-MIKE
Jun 07, 2008 | Haier Refrigerators
Refrigerators Logo
106 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
