GE (PSS26MSRSS) Side by Side Refrigerator Logo
Posted on Jul 10, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I own a GE Refrigerator (Model PSC23SGRC ss) and the ice/water dispensor display unit on the front stopped working.there is no water coming out nor ice...but the refrigerator does make ice it is just unable to dispense the ice or water. Also sometimes it make this wierd clicking sound for 10 mins like 3 to 4 times a day...when this is happening if i open the refrigerator the lights keeps dimming and dipping..what should i do?
Matthew Panas
Level 2:
Habit-Forming:
New Friend:
  • Expert 53 Answers
  • Posted on Jul 12, 2017
Matthew Panas
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
53
Questions
0
Helped
19778
Points
141
Hello:
Your main control board is defective...It is located in the back of the fridge.. Very common problem with this model..
Part #WR55X10942
5 Related Answers
Anonymous
  • 291 Answers
  • Posted on Aug 21, 2007
SOURCE: GE SIDE X SIDE Dispenser problem
Sound like maybe a dispenser board short... you could try taking of the top hidge cap on the freezer side unplug the power to the board there for 30 minustes or so plug back in and see if it can reset to default and try that before u have to change board
Anonymous
  • 35 Answers
  • Posted on Mar 27, 2008
SOURCE: GE Ice dispencer not working properly
for a very informative video on trouble shooting your refrigerator http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
I had the problem with no water or ice dispenced and the lights dim when dispencer is used and the refrigerator compresser stops after using the dispencer and had to unplug and reset unit. GE DID NOT WARANTY IT. I bought a new motherboard for about $88 and fixed my problem. As the video shows there can be other problems that will cause some of these symptoms but not all at once. My frige was only 2 years old when this happened.
Anonymous
  • 1665 Answers
  • Posted on Jul 04, 2008
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Anonymous
  • 93 Answers
  • Posted on Jul 17, 2008
SOURCE: GE PSC23SGRC SS refrigerator (Arctica) Profile
Main board is out. Replace. Located on rear of unit
A
Anonymous
  • Posted on Aug 02, 2008
SOURCE: Kitchenaid refrigerator in door water/ice dispensor
Look here.
http://www.fixya.com/support/t219770-kitchenaid_superba_kscs25fkss00
How can i check ,no ice or ice dispensor out of my GSS25JSRF SS refrigerator
I assume water dispenser works. One possible solution: the plug under the plastic cover has come out of the socket. Remove the plastic cover next to the ice cube maker and reseat the plug.
1helpful
My GE Profile psc23sgrc ss will not stop beeping ... the door is shut. Can i bypass the sensor?
ck door switches, they just pull out. you may have two in freezer. one is ice interlock.
GE Profile Refrig model PSC23SGRC ice maker stopped making ice. Water is ok, just stopped? Is this common? Its only 4 yrs old
Your model has an electronic ice maker part number Click Here=> WR30X10093 When the electronic ice maker fails you usually need to replace the complete ice maker. You can test the ice maker by filling the tray with tap water. If the water freezes aand then drops the ice then the water control on the back of your refrigerator is the reason. The water control valve is Click Here=> WR57X10032 Either way let me know your results, Thank You, Sea Breeze
Ice maker not working
OK, that should be no problem. Test your ice maker and fill with water if empty of ice. If full of ice and not moving to dump tell me. I need to help you locate the problem doing that and answering will tell me the problem. Also look around the door frame and inside for the model Profile that you have. and get back with me as soon as possible, Thanks Sea Breeze
5helpful
Water stopped coming out of the front
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
There is also a dispensor heater , you may want to install , pt # WR49X10173 . This should keep the water line from freezing again , if it turns out to be that problem .
3helpful
GE model PSC23SGRC SS refrigerator freezer door disassembly
Access from front of freezer door. Trim is just pushed into friction holders. Selector area snaps in. Phillip screws under that removes ice shoot.
GE Model PSC23SGRC SS Serial #RH418861. Refrigerator make a howling noise Dave [email protected]
I suggest a defrost with doors open over night, what often happens with this model is that you get an ice build up near the fan which causes an extremly loud noise, very common problem.
No water from Water dispensor
Have you checked your water valve? I dont have your model number but you could have what you call a double water valve and one side of it may be out, alternately you may need to change your water filter if you havent done that yet. I have seen were the water stops dispensing first and then stops making ice. have you changed the filter lately? If not change it then if that doesnt work check water inlet valve...
3helpful
GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
2helpful
2answers
Top Refrigerators Experts
vince
Johnny 1000
