Tip & How-To about Cameras
Transfer photos from Camera to PC
Hello and welcome to FixYa!
To transfer your photos from your
Digital Camera to PC, Follow the given steps:
1.First connect your digital camera to your computer.
You can do this in two different ways:
  • Use a USB cable:Most digital cameras come with a cable that connects the camera to a USB (Universal Serial Bus) port on your computer.
  • Through memory card:A memory card reader is a piece of hardware that plugs right into your computer. You remove the memory card from your camera and insert it into your memory card reader, similar to the way you might transfer a file between two computers using a floppy disk.
Now connect USB cabe or Memory card Reader to the port of the computer
2.Once you've connected your camera to your computer or inserted your memory card into your memory card reader, your computer will detect the connection and ask you what you want to do with your pictures. If you connected your camera with a USB cable, click Microsoft Scanner and Camera Wizard, and then click OK
If you are using a memory card reader, click Copy pictures to a folder on my computer using Microsoft Scanner and Camera Wizard, and then click OK.
3.When the Scanner and Camera Wizard appears, click Next.
4.All of the pictures on your camera (or in your camera's memory card) are now displayed on the Choose Pictures to Copy page. By default, Windows XP selects all of the pictures for downloading. If there are pictures you do not want to download, just clear the check box next to those pictures. At this stage, you can also rotate pictures that you took while holding your camera vertically. To rotate a picture, click it, and then click either the Rotate clockwise or Rotate counterclockwise button on the lower-left side of the page. When you have reviewed the pictures for downloading and rotated your vertical pictures, click Next.
5.On the Picture Name and Destination page, type a name for the group of pictures. (This name, plus a number to differentiate each picture, will be applied to each of the pictures you download; for example, if you name the group "Vacation," the pictures will be named "Vacation001," "Vacation002," and so on.) Click Browse, and select a folder in which to save your pictures.
6.If you want to erase the images from your camera's memory card to make space for new ones, select the Delete pictures from my device after copying them check box, and then click Next. The Scanner and Camera Wizard copies the pictures from your camera to the folder you specified and then removes the pictures from your camera's memory card.
7.On the Other Options page, you can choose to publish your pictures to a Web site or order prints. If you have finished working with your pictures, click Nothing, and then click Next.
8.On the final page of the wizard, click Finish. Windows XP opens a Windows Explorer window showing the pictures you downloaded from your camera. Your camera's memory card is now clean and ready to store new pictures. If you connected your camera to your computer using a USB cable, disconnect your camera. If you used a memory card reader, return the memory card to the camera.
Your photos are now stored on your PC, ready for whatever you want to do with them, and your camera is ready to take more pictures.
Thank you for Using FixYa!
Cameras Logo
how do i switch photos from internal memory to a memory card
Hello and Welcome to Fixya!
To switch the photos
from internal memory to a memory card follow the given steps:-
  • Insert an SD card into your Kodak V570 camera.
  • Press the "Review" button on the back of the camera and navigate to the photo you would like to copy, then press the camera's "Menu" button.
  • Select "Copy" from the available options and then press the 'OK" button on the back of the camera. Navigate through the available options by using the arrow keys on the back of your camera.Select "Picture" from the list of options that appears to transfer just one picture. Select "All" from the list of options to transfer all of the photos from your camera's internal memory to an SD card.
I hope this solution helps you
For Further assistance, I am here to help
Thank you and Keep Visiting FixYa
how to transfer photos from the camera if without a cd-rom installer?
To transfer the photos, Follow the given instructions:
When you are looking at the back of your camera, on the bottom right side of it there is a little flap that you can lift open to reveal the USB port. You will need the proper USB cord to connect your camera to the computer, it should have come with this cord. The camera must be powered ON when you connect it to the computer. Windows should then automatically give you a popup asking what you want to do. Choose the Open Folder option, as shown below.
You will then see a window with all of your picture files. Copy them all by pressing Ctrl+A and then Ctrl+C. Then open the folder on your computer where you want to save them (such as My Pictures) and press Ctrl+V to paste them.
The other option you have is to purchase a card reader that is compatible with a Sony Memory Stick Duo (which is about half the size of a Memory Stick),
With this device, simply insert your card into the reader, then insert the reader into the USB port of your computer. You will get the same Windows popup as shown above, and you can follow the same steps to copy your photos onto your computer.
I hope this will be helpful for you.
Best of luck, Anymore help, i am here to help.
Thanks and Keep Visiting FixYa
I have connected the camera to my computer, how do I download the photos from there to the computer?
I understand you?re interested in transferring the pictures from your camera to your computer. Please follow the following steps 1: Connect the camera to the computer using the USB cable, U-8. 2: Turn the camera on 3: A window will automatically appear on your display. Please follow the steps given to you by the programme. If no window appears: 3: Go into my documents 4: Find the location of the camera and your pictures 5 Drag and drop from the camera to the computer
want to transfer photos from kodak easyshare cd 50 camera onto computer tou put card into side oyf computer
cannot get photos transferred from C913 camera
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
