Question about Faberware FSS330A Electric Skillet
Need replacement electric on bottom of pan FSS 330A
Posted by ladwigacres on
Anonymous
  • 2,382 Answers
Hi, call Farberware at:
Telephone: 800 809-7166
Days: Monday through Friday
Hours: 7:00 a.m. through 5:00 p.m. Pacific time
They are usually very helpful.
Posted on Apr 28, 2011
Service light reset on 2006 e class 280 sports
You need to access the FSS menu, you get to the FSS screen by bringing up the status on how many miles to the next service.....then hold the reset button for five plus seconds and that brings up the FSS Main Menu. Trying to access the FSS by bringing up the outside temp screen just doesn't work on my vehicle. I was then able to follow my owner's manual directions to reset the FSS Service Indicator.......I got service at a 3rd party Euro Service Center and they hadn't reset the FSS so I was able to do it myself by using the above access process and then following my owner's manual to do the reset protocol.
__________________
2helpful
3answers
Miller welder 330a/bp it will not weld in D/C straight or reverse no ark but will work in A/C its like there is very low volts I was welding and then could not strike a ark
It's likely that your pedal is the problem. Pull the cover and check it electrically - these have been problematic in the past. You can further troubleshoot by selecting constant output and test the output.
Set day, date, time G Shock model? 2688 330A
Hi! Welcome to FixYa!
To change time and date setting in your G Shock model 2688 330A, please follow the steps I'll provide below:
1. Hold down "A" until the city code flashes while the watch is in timekeeping mode.
2.Press "C" to scroll through the time setting options. You will see "Hour" and "Minutes," among other options.
3.Press "D" when the option you want to change is flashing.
4.Press "D +" to change the hour and minutes.
Hope this helps.
Jun 28, 2011 • Watches
4helpful
3answers
How do you change oil in 2006 mb cls and reset service indicator
Practice now is to do a Top Side oil change. This means the engine oil is vacuumed out of the oil pan via the dip stick tube with an oil extractor..
Why ? Because this is quicker, doesn't need a hoist or pit and you don't have to remove the fiddly under covers to get to the drain plug..
Mercedes deliberately places the bottom of the dip stick to withing 1/16" th on an inch of the bottom of the oil pan.
Most if not all engines no have no dip stick, just a cover plug.
Oil level is checked with the cluster and scanner.
Setting is usually around 53mm on the scanner read out.
Oil filter is to the center right of the engine under a screw on plastic cover.
Mercedes special tool needed to unscrew it or generic tool available at auto parts stores.
Oil filter kit comes with large O ring for cover and oil filter element.
To reset FSS you turn to your handy owners hand book and read about the Oil Service Reminder Reset.
It explains how to use the steering wheel buttons and the 'R' button on the left of the cluster.
Several years ago we bought your electric fry pan from QVC..It has been my favorite kitchen item, but recently the electric control that plugs into the pan has overheated and melted on one side...Any...
Try contacting the manufacture to see if you can order one from them or someplace else. The manufacture's name and model number ought to be on the bottom of the pan. Use the Internet to get their contact information. Please rate this advice.
24helpful
2answers
Rounded bottom on frying pan
I did a CPR move on the bottom of my pans by turning the pan upside down and hanging the handle off the edge of my counter. I then pushed down with my palms. It was easy.
Need replacement drip pan for model #GRP4P Part # 22619
my proublem is solved. I was looking for a replacement "Drip Pan" for my George Foremen "The next grilleration" grill. The solution is, I googled it. (George Foremenr replacement parts) It sent me to their sight and as you sroll down the page to the bottom you will see comments from other people who were also searching. And some from other who have found answers. You will see a toll free number where you can order your replacement parts for several appliances. My replacement "Drip Pan is on the way.
12helpful
3answers
How do reset the FSS after Service a and Service b
The instructions for resetting the FSS are almost correct for a 2007 C350.
Change line 1 to read:
1 Turn electronic key in the steering lock to position 2
I would also increase the hold times to 5 seconds.
152helpful
2answers
SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
175(No decimals for they are not taken into consideration)
RATE SET(+TAX Key)
To check if all went well press
CA
C.CE
C.CE
RATE RECALL(-TAX Key)
It should read your tax rate.
Faberware FSS330A Electric Skillet Logo
Top Faberware Kitchen Appliances - Others Experts
Dennis
Ruth summersides
Tom Chichester
Are you a Faberware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
