Question about GE 29871GE3 Digital Answering Machine
I have a GE phone answer unit Model 29871GE3-A. It keeps saying the wrong day and time (about 13 hours ahead). How do I set it right? Thank you very much, God bless.
Posted by tqm3_2001 on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • GE Master
  • 102,366 Answers
Press and hold the SETUP/ENTER button for two seconds to access the setup menu. After the language you can change the time and date.
Full instructions are in the "Changing the Settings" section beginning on page 10 of the manual. If you need a manual you can download one at
http://www.home-electronics.net/ge/pc/IB/29871GE3_IB.pdf
Posted on Aug 08, 2011
Why does my phone automatically advances ahead 2 hours?magicjack problems
Perhaps you did setup the wrong time zone. (wrong country) Check the settings.
Jul 09, 2014 | Cell Phones
How do I change the number of rings before it answers?
Press and hold the SETUP/ENTER button for two seconds, then release to access the set-up menu. After language, time and day, you get to the rings to answer.
Full details are in the "Changing the Settings" section, beginning on page 10 of the manual at
Aug 30, 2011 | GE 29871GE3 Digital Answering Machine
How do I set the time and date on my 43-3829 answer machine?
Hi, here are the instructions for setting the time on a 43-3825, which is a very similar model. They should work for your machine too.
1. Press and hold TIME SET/CHECK/>> until you hear it beep twice. 2. Press ANNC/DAY/<< and the machine will say a day. Keep pressing that button until you hear the correct day. 3. Press REC and the machine will say the hour. Keep pressing it until you hear the right hour. 4. Press >= (the play/pause button) until you hear the right minute. 5. Once you've gotten the correct day and time, press TIME SET/CHECK/>> to save it.
While you're doing this, you can't let the machine sit idle for more than 5 seconds at a time, otherwise it will exit the time setup and you'll have to start over again. Good luck!
Mar 15, 2010 | Radio Shack 3825 Answering Machine
My power was off 2 days. My GE phone shows
the time needs to be set on your answering machine. If you buttons on your base press and hold the day/check button to set the day of the week.
Most likely you don't have the base buttons on your model so on the hand set press the flash button to enter the answerer remote mode. Press the 8 key to enter time set menu. Set hour an dmin using num buttons. Set am/pm using caller id buttons. Press #pause to confirm the setting. Set day of week -/+ and #pause to set them.
Jan 31, 2010 | Uniden Cordless Phone
I lost the information to set up my phone.Is there any way you can e-mail me a short way to put the time and date on the answer machine.the machine model # is 2811ee-2 by ge.Thank you for your help in...
I assume that your model number is 28112EE2 (there is no 2811ee_2). If that's the case then here is how you do it:
1. Make sure the answering system is ON.
2. Press and hold the DAY/CHECK button to set the day of the week.
3. Press and hold the HOUR button to set the hour (a.m. or p.m.). Example: 12AM, 1AM, or 12PM, 1PM.
4. Press and release the MIN button to advance the clock in one minute intervals. Press and hold to increase by 5-minute increments.
5. After the time is set, the real time clock will be displayed on the handset within 1 minute.
NOTE: You must set the day manually. You may choose to set the time manually as well, although the time is automatically transmitted by your local phone company as part of Caller ID service. If you subscribe to Caller ID service, the current time is set automatically when you receive your first CID record.
In case you need a manual for later use (or I was wrong regarding the model number), you can find the right one here.
If you have any more questions, come back here and leave a comment, I'm happy to help.
Feb 25, 2009 | GE (E23771) Phone
How do I access my messages from a remote phone?
yOU CAN DOWNLOAD A COPY OF THE MANUAL FOR MODEL #29871GE3-A AT THE FOLLOWING WEBSITE: www.home-electronics.net/ge/pc/IB/29871GE3_IB.pdf
Feb 22, 2009 | GE 29871GE3 Digital Answering Machine
CL code
My phone was also flashing CL and the 0, after a power outage. After I set the date and time it was fixed. Press the flash button on the handset and use the caller ID buttons to set AM or PM; use the numbers to input the correct time. Then press #. Repeat for setting the day and press # again.
Aug 21, 2008 | GE 29871GE3 Digital Answering Machine
Answering machine
Hw do I reset/reprogram Model: 29871GE3 answering machine? No manual.
Nov 20, 2007 | GE 29871GE3 Digital Answering Machine
GE 29871GE3 Digital Answering Machine Logo
114 people viewed this question
Top GE Lands Phones Experts
martin hogg
Bruce Robin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
