HAVE A PHILIPS 15" WITHOUT
Posted by Jimmie Sill on
  • Jimmie Sill Aug 14, 2012
    IF THE PICTURE IS COMPLETELY DARK AND NO SOUND IT'S TIME TO CHANGE THE POWER SUPPLY.
Rossiel Gomez
  • 517 Answers
Good day!
Actually if your TV have problem like that it is not on the inverter.That problem could be on the power supply or the system board.
Follow this D.I.Y procedures to find the exact problem of your TV.
  1. Remove the back cover of your TV.
  2. After that,find the power supply board.
  3. If you already found the power supply,plug-in your TV and power it ON.Check the input voltage of it,using multimeter (AC range).If the power supply have no input voltage the problem could be the power cord.Replace it.
  4. If the power supply have the input voltage,try to test the output voltage if have 5vdc for the system and logic supply,12vdc for the sounds and 24vdc for the back-light inverter.Use your multimeter tester (DC range) to test that.
  5. If the power supply have a voltage outputs such as 5vdc,12vdc and 24vdc and the problem is still there.The problem could be the main board.Replace it with the same type and model # because the main board is no very difficult to fix and its very sensitive.
  6. If the power supply have no output voltage or the voltage is too low,just ignore the step # 5 because the problem is not on the main board,its on the power supply board.
Check the following to fix the power supply board:
  • Fuse: Check the fuse if it is busted or blown.
  • Power transistor (regulator): Check the regulator if it is shorted or leak.
  • Resistor: Check the resistors specially the one that have a low resistance that near the power regulator.
  • Capacitor: Also check the capacitors if it is leak or bulging top.
NOTE: If you found any defective parts or components that mention above replace it with the same value,type and ratings.
I hope this solution will be helpful.Thank you and good luck.
Posted on Apr 28, 2011
How do I fix a Philips tv
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 01, 2016 | Philips Televison & Video
Have no picture or sound
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Oct 17, 2015 | Televison & Video
I have a philips 42pfl7432d lcd tv, where the sound works, but the picture does not come on. Ambilight works with the remote
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board,will get ur pictuure back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlighht board for the replacement.It a long board in shape.
Mar 09, 2010 | Philips 42PFL7432D 42 in. LCD Television
Picture come on for about 2-3 minute, then goes out has sound no picture, red light come on near power button
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board to get the picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
Mar 03, 2010 | Philips 60PL9200D Projection Televisions
My Polaroid TLA-01511C has sound but no picture...what do I do
Replaced the LCD inverter backlight board is dead.After U replaced this LCD inverter board.U will get ur picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board.It a long board shape.
Feb 21, 2010 | Polaroid TLA-01511C 15 in. LCD Television
The picture went out on my Philips 37pfl5332d TV
Have sound?Ur LCD inverter board is dead.Replaced this board to get picture back.It usally a long board.Tries Shopjimmy.com,Ebay.com for the replacement board part.
Feb 15, 2010 | Philips 37PFL5332D 37 in. LCD Television
No sound and no picture. Tried several power
Its Your lcd control board or inverter boards causing this problem. Either board(s) need to be replaced, if the LCD control board developes a fault condition it will cause the inverters to strobe which in turn causes the backlight lamps to flicker .... if the dc-to-dc converters on the inverter board or series resistors open up this will also cause the same affect.....
Nov 03, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Tv with sound but no picture
ur video inverter board is ded.
Need new one.if u lucky it just lose.
Aug 14, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Flat tv, sound but no picture. have tried
I had one that had a black screen and fixed the problem by repairing the inverter. When I opened the unit I looked at the capacitors on the inverter board and found them swollen. I looked at the bottom of the board and found that the fuse had opened up. The caps were a cheap quality low temp variety 150uF at 25V I replaced them with 330uF 25 volt 105C caps. I then replaced the 2.5A surface mount fuse with an axial 2.5A pico fuse and the TV worked beautifully.
Jun 12, 2009 | Philips 15PF5120 15 in. LCD Television
No picture
Mar 26, 2009 | Philips 15PF5120 15 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
