You might have to
physically unplug the leads for this cd/dvd then plug them back in or Click on
Start, Run, and type regedit and press
Enter HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder
is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the
following names in the right hand column. Upper
Filters Lower
Filters Upper
Filters.bak Lower
Filters.bak
you might have to uninstall
then reinstall your DVD/CD or uninstall the driver then reinstall for this
device
click start control panel
administrive tools,computer management,device manager scroll down cd dvd rom
drives right click you can you can update driver,roll back driver,or
select properties general
troubleshoot, select driver click to reinstall drivers click update
driver or uninstall then reinstall
if this does not fix the
problem it might be a registry problem
Close all open
programs
Click on the plus signs (+)
next to the following folders
If any of the above keys shown in step
4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You
may also want to open Device Manager and verify that the yellow exclamation and
error code on the CD or DVD drive is gone.
hope this helps
I don't know why but this issue is my favorite one. I have created a technical blog for this even. Go to reyfrancisbasa2.blogspot.com where you can get a graphical step-by-step resolution to this issue.
I hope it helped. Thank you for visiting FixYa! have a nice one!
